Going hipster bar end
Moderator: VTRDark
Well not really. Thinking about some bar end mirrors. Anybody got some to go or can you offer recomendations if not.
Re: Going hipster bar end
I have Oxford ones and they are pretty good, but make it much wider.
Cheers Duffy
Width shouldn't be an issue. Don't filter alot and don't use it to commute, well not yet anyway, and not really living in a very built up area.
They are pretty good for a small mirrors and don’t blur through vibrations.
Slow down or tighten them up & use locktite on the bolts.
Mine have never moved tbh unless I knock them in the man cave they are pretty well fixed.
Well I must be very limp wristed as I can't see to tighten the buggers up enough.
Had a little play and will test out tomorrow, weather dependent
Good luck
Thank you, all being well off to the Elan dam, terrorising the Welsh again
Well all good today, just a little extra ummph required
Result
Splashes of excess beard oil can leave them floppy and liable to slip out when vibrated.
Funny you should say that but since my Corona shadow has turned in to a wee wispy goatie I was wondering if it would adversely effect, tunning, handling or sex appeal. However as I have never experienced any of those I shall never know
