Have you been able to ride it on the road yet?
Thanks, but the bolt pattern is actually the same for the VTR/VFR fuel sender.rollingthunderx2 wrote: ↑Thu Jul 30, 2020 10:19 pm I have the bottom of a Vfr tank with sender hole if you want it.
No, not yet, need to relocate the coolant reservoir (or make a new one) and it's way too hot to really get anything done.Nosepicker wrote: ↑Fri Jul 31, 2020 4:18 pm As said, very impressive work![]()
Hehe, I assume if you're interested in trying it yourself you'd have learned enough at this point to understand most of the lingo, so no offence taken ;)Richard wrote: ↑Mon Aug 03, 2020 10:52 am Excellent news. Keep it up, keep us all posted. Most of this, tbh and in no way am I criticising your write up, went over the old noggin. I am a bit prehistoric and was at the back of the line when technical brain power was being dished out. However the more I read the better and less intimidating it gets. Not that I am about to junk my carbs![]()
An HRC reservoir fits in the same place very neatly indeed....4x2 wrote: ↑Mon Aug 03, 2020 7:46 pm
And this is because couldn't be bothered to find a better solution, just made a 30mm long spacer that goes between the bracket & fairing, put a tyrip around the front mounting point and wedged the reservoir in there.
Worst part is that it actually doesn't look half bad and fits pretty well...
