Rear header pipe to link pipe back of swing arm gasket blowing big time, after reading some posts onsite I have in preparation purchased.
4 x stainless studs and nuts plus header exhausts gaskets
graphite gasket for link pipe
s/s exhaust clamps
To fit rear link pipe gasket.... headers removed loosed off with a view to replace header studs with s/s plus nuts
Best practice if studs nuts seize (They will be)
1. socket long extension tap with hammer
2. Quality Nut splitter first or a bolt nut remover https://www.screwfix.com/p/erbauer-bolt ... lsrc=aw.ds
3. nut removed with splitter attempt to remove studs
4. nut removed refit just using S/S nuts do studs later.
Pairs blanking kit purchased to remove some pluming
choke cable that's as snapped at collar replaced at same time ( keeping an eye on the plastic snappy bits)
These will be fitted when exhaust sealed
Any advice would be appreciated
