That's the crazy thing. I'm even starting to like the Teal ones now and I think the Blue one are quite sexy
Congrates on the return Jamoi
You always have to take things too far...Pete.L wrote:I'm even starting to like the Teal ones now and I think the Blue one are quite sexy![]()
Sorted that out for you young’un!
Or course they are, but then I'm probably a little biasedJamoi wrote: ↑Thu Aug 12, 2021 6:19 am Cheers dudes, it's pretty amazing to have it back and I'd forgotten just how much work I'd done to it![]()
Just needs a few bits for the mot, then I'll enjoy it for a bit and hopefully give it a proper make over during the winter![]()
I think the looks of these bikes are getting better with age, do you reckon?
MacV2 wrote: ↑Wed Aug 18, 2021 6:10 pm Rode home from work...Hammy is playing up... Seems to be holding back under load... Revs up fine with the clutch in but goes all boggy when clutch let out...
It's been fairly dry so not water in the works... Plus it P'd down last week & it ran fine.
Suspect electriacal. Start simple I'll change the plugs & try it. Then the ecu & spark box... last will be coils.
Of course it could be fuel...The tank was rusty so had a clean & new tank fillter + inline fillters.Those will be checked when the tank is lifted to do the rear plug.
I'll also check the choke nuts...
If worse comes to worse I have enough bits to do swappsies to find the culprit.
Mac strikes again . You’ll need a bigger shed soon or kick frank outMacV2 wrote: ↑Sat Aug 21, 2021 4:19 pm No.15
Yep another Storm for the collection...
Our freind Murv decided he wasn't using this enough & was gonna E-bay it I made an offer & he accepted it.
Rode it over today.
Nice cans, needs a few bits doing some rusty bolts, rear tyre is a bit low...Rim stripes may have to go. Not sure about the mirror extenders... I'll give a going over as soon as I get time wait till Sept 1st & tax & insure it...Maybe...![]()
Good find MacMacV2 wrote: ↑Sat Aug 21, 2021 4:10 pmMacV2 wrote: ↑Wed Aug 18, 2021 6:10 pm Rode home from work...Hammy is playing up... Seems to be holding back under load... Revs up fine with the clutch in but goes all boggy when clutch let out...
So that turned out a bit easier than expected.
As I was thinking electriacl the first ort of call was to check /swap the plugs.
So lifts up tank...
Seems the rust treatment I did on the tank wasnt that good after all... Bloody good job I put the inline filters in...
So I did what I should have done in the first place & swaped the tank from Dresden over. Had to faff about sorting some replacement fule lines out. Boxed it all back up bunged some fule in... Fired up & ticks over nicely... Started raining of course so I will take it for a spin/test tommorow...
Might have been easier just to pop out & get some new fillters but thats them feked after just about 800 miles...
Oh & the brand new £40 OEM in tank fillter is also already too swollen to pull it out...
Still look on the bright side... see next post...![]()
