In the next couple of months the pair of wheels purchased a while ago will be getting a refurb, any prep I should do before handing over for powder coating.
Was going to leave old wheel bearings in as a new bearings are to be fitted when wheels returned.
as long as the power coating company know what they are doing you dont need to do anything. BUT
I have seen wheels come back from PC where they haven't masked off the key areas like:
the bearing & seal machined diameters
the faces where the disks are bolted to
the disk bolt threads
and I have seen a slow leak of pressure because there was a ridge in the coating where the valve was fitted.
also seen it done so thick that the coating pinged off if you dropped an 8mm socket onto it from 5".
so the key prep work is to make sure you go to a supplier who does bike wheels all the time. if they put PC on the bearing pockets or on the disk faces, it is almost impossible to get back to the precision size or alignment that is needed.
mjvw wrote: ↑Fri Aug 20, 2021 3:25 pm
Thanks great advice, was just thinking of getting them painted not sure what to do but plenty of time to make my mind up.
PC is nice if done properly as Al said, but paint is easier to touch up...Chip PC & you have an issue getting it matched.
Personaly I would take the bearings out...worth checking with the person doing it they might insist you take them out or charge you extra to do it...
Third option...have them dipped.
Pc is to problematic for wheels unless it’s done buy someone knows what they’re doing as others have said .
Personally with wheels painting is the best option .
was going to go down powder coating on my other bike will now really clean , and spray them with rattle tin when able they are only satin black so even i should manage that lol
no kid but it sure makes your ma mad (fastest indian)
i always wanted to ride a v twin now i got one i still cant
Well was going to paint but change my mind and as mentioned in other post very with happy results, swing arm and foot rest hangers next for satin black powder coating.
