Hi all,
Does anyone have Harris rear sets on their firestorm ?
And if so would you mind measuring the length of the gear shifter rod for me ? I need to find a replacement .
Thank you
Harris rear sets ? Who has any? Favour request
- freeridenick
Re: Harris rear sets ? Who has any? Favour request
I can measure mine later but the length depends on where you fit the pegs and what pattern you have the gears in.
I use 'race' pattern and my pegs are as far back as they go, and one down from the highest. I had to get a longer rod to get the lever in the right position. Harris have various lengths. Measure the distance between the rose joint bolts with the pegs in the right place and buy the one closest.
The set I have which are not fitted at the mo... The rod is 240mm...
