Popkat- the housewives favourite.....popkat wrote:lloydie wrote:I'll be there on the 6th as I like to take my mum out for the day to watch the racing
VFR750/Storm crossbreed race bike project.
Re: VFR750/Storm crossbreed race bike project.
Great report poppers on the days racing. good points are you know whats needing doing
- bigtwinthing
Hi Poppers, Can you do a reminder 2 weeks before if you go to donington. I may be able to make that
bigtwinthing wrote:Hi Poppers, Can you do a reminder 2 weeks before if you go to donington. I may be able to make that
Will do
......or you could push the button on your phone and ask it to remind you, save poppers having to wipe your butt for you! Lazy git!bigtwinthing wrote:Hi Poppers, Can you do a reminder 2 weeks before if you go to donington. I may be able to make that
- bigtwinthing
Kev L wrote:......or you could push the button on your phone and ask it to remind you, save poppers having to wipe your butt for you! Lazy git!bigtwinthing wrote:Hi Poppers, Can you do a reminder 2 weeks before if you go to donington. I may be able to make that
OY, i am not that technically geeky minded. I have a New I phone 6 for work and can't bloody use it haha
I know this an old thread but what exactly did you do to the sprocket carrier to make it fit. I'm doing a similar thing but if I cant get it to fit I might have to try a CBR1000FL/M rear wheel.
It's machined down where the sprocket bolts, studs removed and replaced by bolts also machined in the centre. I can't remember the measurements though, 8mm rings a bell ?, there is also a stepped 3mm flanged spacer. front sprocket is RC30 in 520 pitch. you'll need to make measurements to be sure you get it right though. It wasn't difficult, just lots of measuring.
Excellent, thanks, and did the sprocket carrier bearing have to be recessed as well
No it's machined almost flush with the outer edge of the bearing so there is no dust seal, not really a problem as it's a sealed bearing anyway
The spacer that goes inside the sprocket carrier, the one from the inside I cut in half, then the outer spacer I had made to go half way into the sprocket carrier bearing, it's a tight fit so the spacer never falls out.
That's absolutely brilliant, it all makes sense now. Thank you for sharing this information
I've taken the bearing housing down 8mm, the outer part 10mm and the face that the sprocket bolts to 10mm, does that sound about right? Looking at the photos of the sprocket from the back 10mm looks about right.
Sounds close, maybe I went 8mm all round, not sure ? but 8mm sounds right for bearing housing, if there is extra off the sprocket carrier it's easy to space the sprocket for alignment
At the front end, were the Firestorm forks shorter than the VFR forks and if so did that make any difference.
Yes much shorter but it's easy to get around. the VFR has massive sag on the forks so when you set the storm forks up to say 27mm sag the difference is much less than it initially looked, my bike handles well and I run standard Firestorm handlebars with the forks flush at the top (I have 0.90kg Springs) if you want to raise the front then either Clipons below the yoke or the better option of risers for conventional bars.
