sirch345 wrote: ↑Sat Mar 12, 2022 9:18 pm
mjvw wrote: ↑Sat Mar 12, 2022 7:44 am
JCR wrote: ↑Fri Mar 11, 2022 7:31 pm
Thanks buddy, Now the pyramid one is really starting to grow on me, now I’ve looked at it a few times online, it’s kind of a half way house between a full lower faring and a moriwaki style belly pan to me. I wasn’t keen at first but I’m really starting to like it now that I’ve seen it on a few bikes online. Can I ask what was the fit like? I’ve just finished fitting a power bronze under tray and it was a pain in the butt lol
I am wondering though if I’ll have any issues with clearance underneath at the rear of the pyramid one as it comes quite far back and until I’ve finished my new custom exhaust system to clear the single side swing arm I can’t be sure how much clearance I’ll have there but I guess I could always trim up the faring a bit if I have to.
Jon
A rail runs down both sides of the bottom of the oil pan, two sump bolts on each side to fit rail to pan, then belly pan bolts to captive lugs on the rail.
I have not found ground clearance an issue. But I have a few scraps underneath due to dropping of curbs.
Its reasonably roomy around engine area.
I have altered it a little remove some meat from the belly pan on the gear change side as my size 11 would catch the edge of the belly pan. Very easily done with the Dremel.
The quality of the belly pan is fantastic it still in good shape after 20 years on the bike.
That will be due to it being made in fibreglass IIRC
It looks like a very good colour match in the photo
Ok great thanks for the info, looks good and fits well, sounds good to me
though I do prefer abs plastic over fibreglass due to the lighter weight and being more durable so that’s about the only negative for me now. I’ll have to have a good think and make up my mind lol
