Front brake splitter location/positioning
Hi, does anyone have a photo of the correct front brake splitter positioning?
Mines been messed with and I want to return to stick if I can.
Thanks
Pat
Thanks
Pat
Re: Front brake splitter location/positioning
Here is what I have. The master cylinder hose to the bottom.
That's bad! The fact that it is mounted to a static bracket when both the top and bottom hoses have to rotate with the bars is bad practice!
Mine runs double hoses from the master, so I removed the splitter a long time ago. but if I remember, it should mount on the bottom yoke, so it rotates with the bars.
Thanks. I'll check the bottom yoke for a suitable place
I too run the double from the master cylinder think its called race set up, its a nice simple solution.
Storming About
I too run the double from the master cylinder think its called race setup, its a nice simple solution.
Below f2 standard setup.
Storming About
That's very helpful, cheers
Pat ... so looking at the picture from MJVW, you don't have the standard VTR splitter. but you should be ablate move it to mount onto the threaded boss on the bottom yoke and try and sort the hose routing to work
Cheers, but as it happens, one of the 2 existing lines is weeping from its end, so I'm going to order a new set and convert to the 2 line 'race' set up anyway.
Annoying that I didn't spot this weep before as I've just rebuilt the master cylinder thinking that was the reason I couldn't get a firm lever even after rebuilding the calipers!
Well spotted AlAMCQ46 wrote: ↑Fri Apr 29, 2022 10:14 pm That's bad! The fact that it is mounted to a static bracket when both the top and bottom hoses have to rotate with the bars is bad practice!
I noticed the hose from the master cylinder looks like an OEM rubber hose (may not be from a Firestorm) which kind of defeats the idea of having stainless steel braided brake hoses for the other two
Yes, the bike had various oddities that I'm slowly rectifying!
turns out that was a lucky findpat_986 wrote: ↑Sat Apr 30, 2022 6:06 pm Cheers, but as it happens, one of the 2 existing lines is weeping from its end, so I'm going to order a new set and convert to the 2 line 'race' set up anyway.
So how do you know Rob ?fabiostar wrote: ↑Mon May 02, 2022 9:33 pmturns out that was a lucky findpat_986 wrote: ↑Sat Apr 30, 2022 6:06 pm Cheers, but as it happens, one of the 2 existing lines is weeping from its end, so I'm going to order a new set and convert to the 2 line 'race' set up anyway.
Annoying that I didn't spot this weep before as I've just rebuilt the master cylinder thinking that was the reason I couldn't get a firm lever even after rebuilding the calipers!![]()
you really dont want a line letting go
dont ask how i know lol
He was on one of the bloke's on the NI run a few years back, how do you know him?MacV2 wrote: ↑Tue May 03, 2022 9:36 amSo how do you know Rob ?fabiostar wrote: ↑Mon May 02, 2022 9:33 pmturns out that was a lucky findpat_986 wrote: ↑Sat Apr 30, 2022 6:06 pm Cheers, but as it happens, one of the 2 existing lines is weeping from its end, so I'm going to order a new set and convert to the 2 line 'race' set up anyway.
