wiring
- northmanuk
- Contact:
wiring
can anyone nhelp im trying to wire up thermostat i have main plug green, black round connector screwed down wire but there is another wire i found black flat connector where does it go
no kid but it sure makes your ma mad (fastest indian)
i always wanted to ride a v twin now i got one i still cant
Re: wiring
As far as I can see there are only 3 wires going to the thermostat housing.
(1) One wire has the big Green connector block as you mentioned.
(2) Underneath the Green connector there should be another wire connected to the Thermosensor (this is like a threaded bar terminal connection if that makes sense).
(3) The third wire has a round ring connector type which fits under one of the thermostat housing bolts, I think you mention that one as well. That ring connector has a spade connector on the end of it making it quicker and easier to remove I'm guessing.
So if you still have a spare wire it must be for something else
HTH,
HTH,
- northmanuk
- Contact:
Re: wiring
its a light weight black and green wire
Re: wiring
There is a wire that is black with green rings that goes to the thermostat housing, earth wire.
Check out the photo's I took from my VTR,
- northmanuk
- Contact:
Re: wiring
thats what the wire looks like but i got that on with spare wire left over
- northmanuk
- Contact:
Re: wiring
could it be a frame earth .that's the only wire i can see on wire diagram that is singular. it bolts to frame then changes to green in( heyes manual there is a black circle which it connects too.
Re: wiring
I'll have another look at the Haynes manual, not that I will see anything more than you lol.northmanuk wrote: ↑Thu Aug 11, 2022 5:21 pm could it be a frame earth .that's the only wire i can see on wire diagram that is singular. it bolts to frame then changes to green in( heyes manual there is a black circle which it connects too.
Wherever it it goes it can't be very far away from the thermostat housing, a frame earth a possibility
- northmanuk
- Contact:
Re: wiring
if i had any hair id pull it out lol
Re: wiring
I have been thinking about this odd wire and did a bit of digging as I haven't come up with anything from my Workshop manuals.
This shows the number of earths (ground) points on the bike, and explains where they all go:
The link here is where I got the diagram from, thank to Erik:
https://www.vtr1000.org/phpBB3/viewtopi ... 84#p451284
Re: wiring
I'm posting this photo up on behalf of northmanuk. This is the wire and connector he is having difficulty in working out where it goes:
Re: wiring
OK but whats the other end conected to ?
That pic is a bit chocolate teapot...
It looks like the wire that goes to the top of the thermostat... Look at your pic it has the same green dot on it... Maybe the ring conector is missing...
- northmanuk
- Contact:
Re: wiring
i have much heavier ground to the thermostat two green wires
the green socket
the wire to round post
then this odd wire which i put on a female clip i found on old thermo
the green socket
Re: wiring
Does the wire in your photo come out of the loom at the same exit as the 2 wires that go to the big green plug? (the 2 wires are pink with a white line, and green with a black line if I remember correctly).northmanuk wrote: ↑Thu Aug 18, 2022 7:09 pm i have much heavier ground to the thermostat two green wires
the green socket
As I have ringed in red below on my bike
- northmanuk
- Contact:
Re: wiring
yes
Re: wiring
Ah, well that wire being one of those 3 is the correct one that goes on to the thermostat housing as shown in the photo of my bike below, the one you have fitted must be for somewhere else. Try looking to see what other wire(s) exit the loom with that wrongly fitted wire.
