At the front of gearbox housing I tried to pull this rubber booted switch cable thing.
I pulled a bit too hard, thinking that it must have been pushed in there by someone - maybe expecting spade terminal.
Quite cross that the rubber boot broke, revealing two yellow (or one yellow and one yellow/white stripe) cables.
I need to get this out as it is the only thing left holding the loom in the frame (it goes across the bike under the coolant reservoir)
What is it, can I keep pulling and how much more?!
TIA
