Problem with starting engine
Hi i have problem with starting the engine, i can easily push start but it will not work with starter button making strange noise
Re: Problem with starting engine
Starter motor...
Head to ebay & find one from a CBR or Blackbird. Same part but located on rear of the motor so normally much cleaner than VTR ones.
Did you take it apart or just clean the outside ?
the issue is the starter clutch beyond the freewheel
the problem isn't in the starting engine, the problem is in the starting clutch that is worn
