Hey guys, bit of a different post for you guys but i have recently brought a vtr1000f of someone and he was fully confident on the fact it ran, but anyways i no have got everything mounted and wired up on the harness but not all the handlebar wires, i believe it is a u model so the key isnt wired into the thing so i can just use a screw driver to spin the actual mechanism for it to work, it takes me to full display when i spin it to ignition and the neutral light comes up same with the display like fuel and time and k’s and the low oil light sensor which it should cuz i dont have that much oil in it but from what i believe it should run,
i got the multimeter out and tested the ignition coil’s with the ohms and i set it to the function where it beeps to tell u and in got beeps on both female and male part of the plugs, same with the voltage on it, it gave me around 115v, but then i took off my cdi in suspension that was at fault, i put it on ohms and got no reading at all from the pins coming out of the cdi, same with the voltage only got like 0.02v from the pins, it turns over perfectly fine, im pretty sure i found the killswitch plug and put a switch to that so i am unsure of whats not causing spark.
Also the engine is going into a lawnmower
, im a fabricator so i can make it all sturdy and everything, it has a bull bar and previously did wheelies with the original engine.
If anyone could help that would be greatly appreciated
Cheers, Leon.
