Doing a good bit of work to the Storm just now and one of those things was dropping the exhaust system to polish it all up.
I'm now trying to reattach the exhaust with all new gaskets and clamps. The header gaskets I got are aluminium fibre (https://www.wemoto.com/bike/honda/vtr/1 ... nium-fibre).
I can see that the current gaskets are copper, which are slimmer than the aluminium fibre ones (even when new).
I attempted to torque the downpipe back on with new bolts and studs but the downpipe was sitting away out from the engine surface (gap showing bolt thread).
Is this correct if using aluminium fibre gaskets?? I assumed they would squash a lot more, getting them to the copper gasket thickness.
But what I've ended up doing is warping the downpipe eyelets because it looked like they needed torqued down more (which was way too much, 12nm is the spec).
*Another job I was doing was removing and repainting the subframe, so will post that up soon.
