new member
Potcee
new member
Post by Potcee »
Hello there fellow stormers,
I am the proud owner of an orange vtr firestorm, had it for approx 25 years,
I didn't know this place existed until I did a search for oil cooler pipes :roll: I never thought to look for a specific bb for the firestorm, so I had probably glossed over any search engine results while searching for bits etc.
I bought the bike with 3600 miles on and currently clocking 25k. The bike came with after market Leo Vinci exhaust and k&n filter. And an orange pyramid hugger.
It now has MCCT and I have recently serviced the fork and uprated the internals following a guide that is very similar if not the same as one that has been posted on here. Also added a 6mm spacer above rear shock ( why I waited so long to get round to that is anybody's guess) vast improvement over potholes and turning is a lot nimbler. I also had the fork lowers powder coated.
Also added an led H4 and 2 led position lights mounted on brackets on the top caliper bolt, also 2 bobbins on swingarm for paddock stand
I have already changed the recifier to one that a local bike shop recommended for me as the original went west and boiled the battery.
I replaced the battery with an AGM which was pricey and didn't last for more than 2 years (pos) so it's on its 3rd battery which I shoehorned in the taller varadero battery (extra amps and easier to get at posts)
Jobs that need doing are-:
1. sort out the front exhaust studs and replace flange with a 2 piece stainless one
2 sort out starter motor housing and refurb the starter motor itself
3. Subframe needs stripping back and coating as rust is starting to show on welds etc
4. clutch slave seals
I've had one collision with a pheasant at 70mph and that took out the headlight and central section of fairing.
I do all the maintenance myself with the exception of tyre replacements. As it's fairly easy to work on compared to others.
Look forward to chatting to you all.
Regards
Potcee
Re: new member
Well you got here at last :thumbup:
Re: new member
Welcome to the club. Better late than never!!!😉
Re: new member
Hello and welcome to the forum.What took you so long?
Re: new member
Welcome home at last.
Re: new member
Hi & welcome.
I wouldn't bother with refurbing the starter motor just get on eBay & look for one off a Blade or Blackbird.
It's the same unit just mounted on the back of the motor so less prone to the ravishing the storm one gets.
I recently picked one up for £20 so probably cheaper than buying the bits to refurb it...
Re: new member
Wow you've had your bike longer than I have had mine :lol: I've owned my Storm for 23yrs.
Welcome aboard Potcee :thumbup:
Re: new member
Welcome along sir :thumbup:
ChrisC
Re: new member
Post by ChrisC »
Welcome aboard, :thumbup:
Re: new member
Welcome along, Mac was selling stainless steel split flanges and they are a great upgrade when you replace the rusty studs especially on the front cylinder
Potcee
Re: new member
Post by Potcee »
Thanks for the Welcome guys.
Oil cooler pipes have arrived and been fitted I'm back on the road thanks to MacV2
This place rocks
Re: new member
Potcee wrote: Wed Jul 03, 2024 6:00 pm Thanks for the Welcome guys.
This place rocks
That's good to hear :thumbup: :thumbup:
lazybones51
Re: new member
Post by lazybones51 »
Welcome to the forum :wave:
