Hi Steve, And the very same back to you thanks.Coasty wrote: ↑Tue Jan 07, 2025 12:44 am Hey there Chris,
compliments of the season to you ,I hope the new year has started well.
I have a request , I lent my Firestorm to my brother in law who was over from Australia over the Christmas break to go touring for a few days & while she seams to run ok the idle is all over the place, very unusual as she has ticked like a swiss watch all the time I have owned her. I am thinking it must be fuel, maybe he got some bad gas somewhere ? but before I start tearing things apart I would be interested to hear what you think & maybe point me in the right direction before I charge in & pull the carbs to bits. I did spray some carb cleaner around thinking I may have developed an air leak but there was no discernable change in engine speed so cross that off, possible sticky choke plunger perhaps ? any advice you have will be appreciated
cheers
Steve
It sounds like it could be a fuelling problem as you suggest.
Chokes definitely worth checking out
(1) It might be worth checking the carbs for balance if not done recently.
(2) Depending how old your spark plugs are they may need replacing.
(3) Check all the hoses under the fuel tank for possible splits and cracks etc, including the vacuum pipes.
(4) I did wonder about your aftermarket airfilter at the time of fitting, but seeing as the bike had been running fine with it I think you can rule that out.
(5) Has your bike still got the standard OEM HT coils fitted? Or has someone fitted coil-on-cap type spark plug caps, if so checking the wiring on them could be worthwhile.
That should be enough for you to get on with
Others may post up with some ideas of their own
Good luck with it,
