antivirus software
antivirus software
I need help. I'm lookin for some antivirus, firewall whatever else in the way of protection i need. |Any suggestions???
To stupid to live to young to die.
If you use a program called avast. Its free to download and does the job great! Just type avast in google and its just a case of clicking on the link and following the instructions.
I would reccommend removing any old anti virus first as having 2 on your system may clash against eachother and slow your comp down
various versions are available free but full versions can be bought.
If you are on BTbroadband you can automatically get Norton AV2007 free.
Otherwise I get on with Norton AV and Zone Alarm firewall but I have AVG http://www.grisoft.com/doc/trial/lng/uk/tpl/tpl01 seems good installed on one pc .
Apparently AVG uses less resources than Norton and updates its self more frequently.
Have you anything installed yet? Windows XP?
If so you will have do disable and as bigrich said if you have Norton or similar you have to remove first, Even upgrading to the free Norton from my previous purchased 2006 I have to remove.
- Squiffythewombat
- Contact:
any AVS is going to cain your system resources. Normally a good firewall and a bit of common sense will prevail!
Personally i would avoid norton like the plague unless you want your computer to run like dump, avast is good as its less resource heavy!
Squiffy_The_Wombat
I used Norton for a good few ears but I noticed that it was gradually grinding my system to a halt. Tried Zonealarm but it can be a bit iffy if you need to allow certain thinks through the firewall (like another machine) but the anti virus was OK but again it was getting a bit bloated. AVG for the anti virus was very good but no firewall withoout paying for it. I now use Mcafee security suite. There's a privacy service in it which is a pain in the a%$e so don't install it and the spam killer which is included is a bit keen as it seems to block too much but you can always easily retreive messages that are blocked and it will not do it again but on the whole it seems OK and there are regular virus updates and the firewall seems good. Heres a link to download it. I'm pretty sure this is the full version and you only need youe emaill address to activate it and to get updates.
http://download.mcafee.com/products/lic ... 7019EN.exe
Jeff
Jeff
Get a router to connect rather than a modem, learn how to lock down windows (plenty of tutorials around) and secure your admin account etc.
Then you'll have a hardware firewall in the router, a software firewall (windows built in firewall in XP will do - or Zonealarm is good)
Personally, I'd run Norton. It will only noticeably slow down your machine if you're running a very basic level PC. AVG from grisoft is probably my recommendation for free anti-virus.
Plus having Ad-Aware and Spybot search and destroy completes my recommended security package.
Also, probably most importantly, you need to make sure you update stuff regularly. This means Windows Updates, Anti-Virus and spyware definitions and web browser updates.
I don't understand the resources argument...
I mean, given the damage that viruses or hacks can do, why make such a deal over system resource usage?
With 2 gig of Ram and an 64 bit chip, it's irrelevant anyway.
well i use spybot, and also an internet security programme called kaspersky, [/url] http://www.kaspersky.com you can try for 30 days free then go to http://www.onlinesoftwareshop.co.uk [url] and get the full programm for £17.95 and the best thing is unlike norton kaspersky is not resources hungry
doggit
doggit
I'd agree, AVG, Spybot and Adaware is what i use along with the windows firewall, i had norton b4 and it really slowed my machine down it was gradual over a long time but it just seemed to encroach on everything, tried to replace it with McAfee and that wouldn't even work, kept crashing my machine, so deleted them all and went for the free ones, i've read reviews that did tests and AVG was as good if not better than most of the big names a couple of years ago at detection and prevention.Kitch wrote:Get a router to connect rather than a modem, learn how to lock down windows (plenty of tutorials around) and secure your admin account etc.
cheerz
kev
kev
- storminateacup
On gadget show the other day had a piece of kit similar to a USB stick for antivirus, calleda yoggie pico for £50.
see http://www.yoggie.com would be interseted if anyone has tried one of these.
Gavin
Gavin
