Rear Shock spacer ... confused!!
grahamvtr100026
Post by grahamvtr100026 »
OK ... here is where the confusion lies with me .....
I have been advised its not a good idea to put a rear shock spacer in with the standard rear shock ..... (it can cause instability at high speeds?)
What is it about the aftermarket shock that makes it ok to put a spacer in?
Cheers for any help.
Re: Rear Shock spacer ... confused!!
grahamvtr100026 wrote:OK ... here is where the confusion lies with me .....
It doesn't :!: The main problem is the front forks are on the soft side, so putting a spacer under the rear shock will raise the rear putting more weight on to the front, it's got nothing to do with a standard or non standard rear shock :!:
HTH,
grahamvtr100026
ahhh confusion over
cheers for that mate :) :) :)
