Vtr firestorm problems
Collywog19
Post by Collywog19 »
Firstly Hi guys/gals
hope you can help
Vtr started miss firing etc other day, running on one cylinder, i got home, let it cool down, then had to go out again after to fit new chain+sprockets.
Did over 40 mile trouble free, loving it!
got up for work next day, rode in fine.
On way home, it started misfiring again :(
Had to go out to pick a jacket up, running on one cyl below 6k rpm, after 6k rpm, it would jump into life. and run as normal...
Now ive changed plugs, had carbs off etc and still running weird.
CDI? or any other ideas?
I have had no rev counter ever, i think this is down to cdi , as i fitted new gauge parts etc.
Any help would be appreciated. If only i could get a cdi to test it with lol
Thanks
Colin
Bikes ftw!
Stratman
Post by Stratman »
Check the plug leads for splits in the rubber gaiter. Does the problem happen after rain/washing,'cos that would point to the plug leads in my experience.
Collywog19
Been bone dry here for days. red hot weather
Both plugs have a very healthy spark.
Just bought a CDI to try, atleast it'll rule it out if it dont work, but im suspect it is the CDI.
Thanks
Bikes ftw!
warby221
Post by warby221 »
If like It sounds it happens after the engine gets hot it could be some thing braking down with the heat off the engine and that’s usually some thing electronic
Mind you I would have a check of all the earths first could be some thing that simple
Collywog19
Ok thanks guys
Ill check the earths over tonight
Any ideas where they are? thanks again, being a big help
Colin
Bikes ftw!
Collywog19
Just fitted the new cdi, still the same!
Swapped coils over, still the same cylinder that isnt running properly.
Running out of ideas here, could it be the smaller square cdi box?
Ive had the bike stripped , wd40'd all connectors etc etc.
I have no rev counter, even tho i fitted new clock parts, so dunno why this is.
Gonna have a long hard study of the wiring diagam etc.
Checked that the vaccuum is working, which it is, and tested tank, which is letting fuel out fine.
Thanks from a very unhappy colin lol
Bikes ftw!
Beast
Post by Beast »
No rev counter? Does the speedo play up as well not registering properly?
Collywog19
speedo is 100% fine!
Caps have been changed also. I have 4 bikes so changing bits n bobs is fine.
Im totally at a loss here
ignition pickup?
im totally gutted, been lovely weather too and ive just seized my 2 stroke today lol :(
Colin
Bikes ftw!
warby221
Post by warby221 »
If the Speedos ok but the rev counters playing up it would suggest a problem on the ignition side of things could be anything from the ignition switch to one of the cdi units (there’s two of them)
You need to work though them methodically and don’t assume a now or untested part is working ok
My best guess at the moment with what you have written is a bad connection on one of the terminals or even a broken wire some were
Collywog19
Ive replaced the bigger cdi thing, gonna get the smaller one next to try, Just wish i could borrow someones instead of buying one then it not solving problem.
Ringing a V-twin specialist near me tmoro and see what he has to say.
I had the bike stripped naked, checked wires etc.
Col
Bikes ftw!
I'm inclined to think it is an electrical problem as Warby says.
But then again electrical and fueling problems can give almost identical symptoms.
One thing that has not been mentioned is checking the diaphragm in the carb for a split or hole, obviously in the carb for the cylinder that's giving the misfire.
You did re-fit the TPS (throttle position sensor) when you had the carbs off I take it :?:
Did you remove the float bowls when you had the carbs off, or even just drain them :?:
PS. What's puzzling me is the fact that it will fire properly above 6,000 rpm and not the other way around.
PPS.Had the bike been standing and not been started for a long period before this problem occurred :?:
Stratman
Post by Stratman »
Could it be the old vacuum pipe issue? The fuel tap diaphragm could be perished/holed, meaning only at high revs might there be enough vacuum to suck the fuel through properly?
Collywog19
Cheers lads.
I wombles the TPS when i took them off, the spring shot out never to be seen again lol
new one on its way.
I had the bowls off etc.
Smaller cdi box should be here tmoro.
It hadnt been standing at all been used constant for past 6 month.
I checked the vaccum and its spot on. Pisses fuel out everwhere lol
I'll let u all know how i get on tmoro if cdi arrives.
Bikes ftw!
Collywog19
Ps.
Even with or without TPS it had these problems.
just to let you know lol
Colin
Bikes ftw!
Collywog19
And its still broken :(
lol
Bikes ftw!
