dont bother.Diabolus wrote: not doing that till I've re-sprayed the cam covers, do I need to remove all the old paint of just the flakey loose areas??
just buy 2 nice shiny ones off me
if it doesnt rattle from the top end, changing with engine rpm, when its warm... it dont need doing.lumpyv wrote:iirc the check is supposed to be done at 16k? .
You're right, it's not the easiest of jobs I knowDiabolus wrote:Removing the front cam cover is a ferking nightmare, after using a combination of sockets, adapters and extension finally got the top 2 bolts undone. The exhaust cams on the front pot are -1 thou but within tollerance and cct tension spot on and both pots. Not looking forward to putting cam covers back on ! But not doing that till I've re-sprayed the cam covers, do I need to remove all the old paint of just the flakey loose areas?? I'm planing too etch primer and then simonzi tough black same as what I'm using for front forks, is this okay or is a paint that's for higher temps required ??.
