Either that or take your pick, use either RT, then fit cams with lobes pointing up and in and with the RI and RE to outside. Then move onto the front cylinder. At worst the timing may be 180 degrees out, no problem with starting or valves crashing into piston or anything like that and the bike will appear to run perfectly. You will gain lower end power at the sacrifice of top end. The bike wont rev past 7000 while on the move down the road. If you find it to be 180 out then all you have to do is reverse the cam positions.
See post http://www.vtr1000.org/phpBB3/viewtopic ... egrees+out
When working with timing always turn the crank over by hand a few turns first to make sure everything spins freely before hitting the start button.
