His is yellow so he'll be along at some point !!Chris sweets wrote:Amcq where abouts are you? It's starting to get decent weather now so I'm dying to get out on it
Revving problem
Re: Revving problem
Re: Revving problem
Just lifted the tank, removed the two pipes from the bottom of the petcock and no fuel coming out
Re: Revving problem
just off the A422 10 miles east of Worcester. normal ride will take me past yours on the A44, but i haven't even been out yet!Chris sweets wrote:Amcq where abouts are you? It's starting to get decent weather now so I'm dying to get out on it
Re: Revving problem
that is normal, you need the engine running to generate a vacuum to open the petcock. hence if diaphragm is damaged it won't openChris sweets wrote:Just lifted the tank, removed the two pipes from the bottom of the petcock and no fuel coming out
Re: Revving problem
Right so the bike has to be running when you disconnect those fuel lines to check the diaphragm?
Re: Revving problem
Easier if you put a long bit of pipe onto the nipple on the back of the pet rock and suck
Re: Revving problem
So it could still be the diaphragm?
Re: Revving problem
Just started it up to see if the battery had died (didn't ride it) started fine, held it at 3000 revs, no fluctuation at all
Am I right in thinking it's not a timing issue? Surely if it was a timing issue, the issue would always be there even on idle
