If you back the damper right off you should hardly feel it, then add a click every few miles till you get the best compromise between slow corners and high speed stability
How do i adjust it please it was used and has no instructions with it ,there is a adjustable thing on the bar bit then a inner sort of adjustment on the shock bit
god that ws hard work
Loud pipes save lives!
A metal one will last longerVtrkidda wrote: ,next new rubber chain
I knew some one would say that just.knew it
The little knurled knob or the rod right hand end as fitted. Clock wise is more damping, CCw is lessVtrkidda wrote:How do i adjust it please it was used and has no instructions with it ,there is a adjustable thing on the bar bit then a inner sort of adjustment on the shock bitgod that ws hard work
Thanks mate ill give it a go next time im out
cheers
phil ive got mine set 4 clicks in, feels very good on the twistysAMCQ46 wrote:The little knurled knob or the rod right hand end as fitted. Clock wise is more damping, CCw is lessVtrkidda wrote:How do i adjust it please it was used and has no instructions with it ,there is a adjustable thing on the bar bit then a inner sort of adjustment on the shock bitgod that ws hard work
playerone wrote:A metal one will last longerVtrkidda wrote: ,next new rubber chain![]()
Vtrkidda wrote:I knew some one would say that just.knew it
Damn right, gonna make this bike truly mine and hopefully unique. Searching for carbon fibre look fairing lower and rear hugger as I type. Carbon fibre is the new black!bigspanishmarty wrote:sounds like you won't have a problem there bozzer.........you've caught the vtr modding illness haven't you![]()
CBR900rr Fireblade
ooops sorry kidda, stealth mode from now onVtrkidda wrote:no names on the forum please
ill try it mate 4 clicks
- tankslappa
Well tonight's post should have been "Bled all the hydraulics, brakes are now super sharp"
Instead...
Drained front brakes, completely failed to bleed new fluid through, so now have no front brakes at all. Bleed pipe came off so fresh DOT5 spilt all over the calliper and front wheel.
Rapidly rinsed off with soapy water.
So now I have a bike with no front brakes sitting in a puddle in the garage.
I f*ckin' hate bleeding brakes.
I think I'm gonna take the callipers off, it's like trying to do keyhole surgery trying to lock and unlock that nipple between the brake pipe and the fork leg.
Instead...
give over its a piece o piss, bring it up ere and i'll do it for you! mind it'll be a dodgy ride wi no front brakestankslappa wrote:Well tonight's post should have been "Bled all the hydraulics, brakes are now super sharp"
Instead...
This might help http://www.ebay.co.uk/itm/Speed-bleed-v ... 53df9ad33c or you could get a mate round to to make it easy. Get him to do it.it's like trying to do keyhole surgery trying to lock and unlock that nipple between the brake pipe and the fork leg.
- tankslappa
I know, it should be, but so far the only step which has actually gone right is the bleed nipple weren't jammed!marravtr wrote:give over its a piece o piss, bring it up ere and i'll do it for you! mind it'll be a dodgy ride wi no front brakestankslappa wrote:I f*ckin' hate bleeding brakes.
After that it was down hill all the way (with no brakes!).
They certainly would help! I've been trying to use some EZ-Bleed pipe things, but I haven't used them for a while, and they were for the car. I don't think the bike brake has enough pressure to blow past the ball thingy, so nothing happens!.cybercarl wrote:This might help http://www.ebay.co.uk/itm/Speed-bleed-v ... 53df9ad33c or you could get a mate round to to make it easy. Get him to do it.Brake fluid everywhere
Will the bike gravity bleed? Maybe I should try that. My car's rear brakes did that... Took a couple of hours, but it was most relaxing.
