Virt
Post by Virt »
Woke up and stared at it in the shed for an hour. I can't do this :lol:
Went out on the mountain bike...
Went out in the forby- much more fun, overtaking cars in the snowy outside lane.
mr.john.coates
Post by mr.john.coates »
Went in the shed and sniffed it :( (Smells nice, though)
Too much snow to use the Deauville for work - on my push bike most of last week. Came off on the way home Friday, but nothing new there. He who falls often etc...
Started to make some brackets for a new seat strap. If it works I'll post some details later
NT650V in Red
VTR1000R in Blue
Pushbike in Yellow
Wife in Bed
lumpyv
Post by lumpyv »
took the lidl trickle charger off. started it up. First push. ran it for approx 12 minutes.
best bit was i remembered to open the front door of the garage and the side door therefore not making the whole house fumey.
since then i have been watching the snooker and making a snowman.
lumpyv wrote:took the lidl trickle charger off. started it up. First push. ran it for approx 12 minutes.
since then i have been watching the snooker and making a snomanw.
So either you have a TV in the garden or snow in your front room ??
Which is it we demand answers !
:lol:
AMCQ46 wrote:
cybercarl wrote: Have you seen the size of his back door,
Is that not a gay euphemism? ... :lol:
big enough for a pinapple by all accounts..... :Jaw Drop:
as the new heavy duty ebc clutch springs were on the door mat when i got home i started to put kermit back together .
ignition advancer fitted and new plugs .oil .filter and coolant.
hit the started and it fired into life instantly :D even in this cold -2 .
i left it to worm up to temp and gave it a little stroke
[youtube][/youtube]
picks up faster and smother and idols better .
the search begins now for a sp1 oil cooler :(
i just need a dry day before the end of the month to test the clutch as kermit aint getting a new mot till march and it runs out end of jan .
lumpyv
Post by lumpyv »
:lol:
just got patio doors :lol:
Griff1977
Post by Griff1977 »
lloydiecbr wrote:as the new heavy duty ebc clutch springs were on the door mat when i got home i started to put kermit back together .
[youtube][/youtube]
Great to hear about the work lloydie, especially the +4.
Do you have any top tips or lessons, having now done what I've been thinking of? Did the cable ties work ok?
:D
Griff
Immediate plans:Clean it!
What I did was - I put a bolt ( the shortest one from the clutch cover )in the threaded hole to hold the two gears together and a cable tie in the other .
I used some 10mm hard rubber strip to jam the gears so I could undo the bolt . Make sure the cable tie don't get anywhere near the gears as it will brake :-( . I then undone the bolt easy . Swapped over the advancer and put the rubber strip on the other side of the gear to jam them so I could tighten them up .
Remove the locking bolt and the cable tie --- job done .
Griff1977
Post by Griff1977 »
lloydiecbr wrote:What I did was - I put a bolt ( the shortest one from the clutch cover )in the threaded hole to hold the two gears together and a cable tie in the other .
Brill. Sounds great. I'll not be doing mine for a while but I'll let you know how it goes. Got to sort out electrical gremlins first! Griff. :thumbup:
:biggrin
tankslappa
Post by tankslappa »
I moved mine out of the garage for a few days, because I needed the space for some work on the four wheeler...
Then it snowed!
Could have timed things a bit better!
Oh, and hello again, I bet you thought I'd died in a horrible disc lock related accident didn't you! :Finger1:
good to hear your still around mr slappa...... :thumbup:
