Op Storm Wales 2020 September 11th 12th 13th
Moderators: AMCQ46, geodude
cheekykev
Re: Op Storm Wales 2020 September 11th 12th 13th
Post by cheekykev »
Click on link below for a map of the location of the Bunkhouse
https://www.google.co.uk/maps/place/Rha ... 5?hl=en-GB
Like what you do
Do what you like
Miztaziggy
Post by Miztaziggy »
AMCQ46 wrote:reminder of the proposed route.
https://ridewithgps.com/routes/33643419
and due warning that we will be planning to set off at 9.30 latest, so be ready!
we will go to a petrol station 1st, so don't worry if your tank isn't full.
Al, does the route include that road we did 3 years ago along the river?
How would I get that route into my sat nav on the phone to follow while riding?
Sent from my SM-G960F using Tapatalk
cheekykev wrote: Fri Sep 04, 2020 2:15 pm Click on link below for a map of the location of the Bunkhouse
Morning all, re the location, if you look on the satalite pic on the map link you will see two turnings to the right that take you to the bunk house...
The location marker for that link/postcode is smack bang in the middle of a farm yard. There are two turnings to the right, the first one takes you through the farm yard, so probaly not the best option even if it is correct accordig to your Prat Nav's...
The second turning is probably the correct one & as a guide there is a large phone mast so should be easy to spot even in the dark.
The lane down to the block looks a bit iffy but it can't be any worse than the one into the previous bunkhouse...
I just hope the beds are better... I really didn't like trying to sleep on bare springs last year... :x
Oh & pack your waterproofs we may need them... :roll:
Oh & only 5 sleeps to go...
Not that I'm excited about it...
Much... :Bike: :Dancing2:
MacV2 wrote:Oh & only 5 sleeps to go...
. :Bike: :Dancing2:
You can sleep?ImageImageImage
Pete.L wrote: Sun Sep 06, 2020 4:20 pm
. :Bike: :Dancing2:
Not this morning no...
Up @ 04.30 an hour before the alarm due... :x
and weather forecast looks OK :thumbup: :D
covid forcast looking a bit overcast in wales!!
need to keep your helmet on and visor down all weekend :lol:
Miztaziggy
Question on tyres.
I got my bike out the garage to check it over today and my back tyre was flat as a fart, front was about 14 psi.
I had the rear fitted a couple of months ago for MOT and I think I've ridden bike once since then. Otherwise been sitting in my garage the last 3 or 4 weeks.
Do you reckon that going flat like that is normal, and pumped up and used they'll be fine, or should I be looking to get a pair fitted urgently ahead of this trip?
shouldn't go flat in 3 weeks, need to check for a leak or a puncture.
you should NOT need a new tyre, but it might be worth getting a tyre place to take it off and check the bead and valave
Miztaziggy
AMCQ46 wrote:shouldn't go flat in 3 weeks, need to check for a leak or a puncture.
you should need a new tyre, but it might be worth getting a tyre place to take it off and check the bead and valave
Balls... I'm away in London from tomorrow. I'll have to try and take it Friday morning.
I've pumped up to 42 just now. If it holds that until I'm back from London on Thursday, would you say it's worth risking it?
You could take a pump and some tyre slime, that should see you through, but your tyre fitter will hate you forever if it ruins his trainers when you eventually get it replaced.
Miztaziggy wrote: Tue Sep 08, 2020 4:56 pm
there was a typo in my reply. you should NOT need a new tyre
for me... if it was still holding pressure (anything above 30) when you get home, then I would pump it up and ride it. if its gone too low in 2 days then tyre fitter to look for leaks
We're going to Wales. Bound to be a few leeks*
* Probably better as a spoken comment, to be fair.
Miztaziggy
tony.mon wrote:You could take a pump and some tyre slime, that should see you through, but your tyre fitter will hate you forever if it ruins his trainers when you eventually get it replaced.
Good idea. I'll go get some gunk and stick it in.
