Well you asked for another Ducati build
buzzer
Re: Well you asked for another Ducati build
Post by buzzer »
Things don’t always go to plan… :roll: I dropped the speedo and of course the glass cracked. Very frustrating! My first reaction was to just buy another… then I got thinking… maybe I could repair it? So I made a new bezel out of aluminium and tried to peen it over… first attempt failed, it was too thick, so I made another, and that worked perfectly! One tip when bending aluminium is to aneale it first. To do this mark it with a sharpi pen and heat it.. when the marks disappear, its the correct temperature for annealing! just let it cool…
I was able to turn a new glass out of 3mm polycarbonate, clamped between two pieces of aluminium, and a revolving centre. I guess there are now a couple of advantages… the alloy is more in keeping with the bike, and i was able to remove the GPS logo. While the MOT man is not bothered, (its not a reason to fail) A GPS speedo does not comply with construction and use regulations.
Very frustrating I'm sure, I bet the air was blue :lol:
I like the way you held the 3mm polycarbonate in the lathe. At least you ended up with a better job in the end, well done :clap: :clap:
Thanks for the tip on the annealing for this job :thumbup:
buzzer
Post by buzzer »
This build comes to an end, just in time for spring and the better weather! Took it for MOT today and it passed with no problem… But then again he follows my builds!
I did spend a very frustrating day yesterday.. I measured the voltage to check it was charging... It wasn't! I set about fault finding ( the electrex worldwebsite has a fantastic fault finding section!) and everything checked out, I couldn't understand what was wrong... In desperation I asked my mate to pop round... First thing he di was check the volts... with his meter... It was charging! the fault was my meter!
I will update in a while when I have put a few miles on it... first impressions are very favorable! Its very light and weighs in at 139KG with a bit of fuel in there... On the road it feels torquey and nimble!
That looks fantastic, it may need a hugger to stop you getting smothered from the back wheel though
There's a bit of Honda monkey bike with a stretch swingarm from some angles...
It should feel lively with that weight and power.
Flippin' 'eck Tony you don’t hang around, another fine build, well done 8) 8)
I can imagine it is nimble with that weight and power.
Don't you just love the simple fix when you are looking for something more complicated, well done to your friend and his multimeter :D :D
buzzer
Post by buzzer »
As this build finishes my mind turns to the next project, I have 6 months to think about it as I like to ride over the summer months... Yesterday I moved the cars and bikes out of the garage so I could give it all a good clean. Moving the bikes around made me realize just how heavy the Guzzi feels (200kg) its manageable for me at the moment, but I am sure a time will come when that also becomes too heavy... The Ducati's weigh in at 165- 168 KG and with the high bars, they are easy enough to move around. The Honda feels super light in comparison! Incidentally I rode a Honda Montesa last month... at 80 ish KG that felt like a push bike!
I think the next build will be a single cylinder, and as powerful as I can find... which means going for a watercooled bike. maybe quite modern, and perhaps accident damaged/reparable salvage... we will see, watch this space! suggestions welcome! :thumbup:
MK_WF
Post by MK_WF »
buzzer wrote: Sun Apr 07, 2024 12:11 pm Things don’t always go to plan… :roll: I dropped the speedo and of course the glass cracked.
I modified quite a number of RD350 with self made speedo/tach/water temp stickers.
One part of the job was to pry open the aluminum ring at the backside with a small and sharp screwdriver.
After removing the stock coating from the gauge plate, I put my design on and reassembled everything.
The last step was to put it on a hard surface with a soft cloth in between and cautiously hammer the aluminum back to close the ring again.
The result looked like this:
(BTW: it's for sale, if someone needs it)
Bye
Martin
buzzer wrote: Sat Apr 13, 2024 10:27 am As this build finishes my mind turns to the next project, I have 6 months to think about it as I like to ride over the summer months... Yesterday I moved the cars and bikes out of the garage so I could give it all a good clean. Moving the bikes around made me realize just how heavy the Guzzi feels (200kg) its manageable for me at the moment, but I am sure a time will come when that also becomes too heavy... The Ducati's weigh in at 165- 168 KG and with the high bars, they are easy enough to move around. The Honda feels super light in comparison! Incidentally I rode a Honda Montesa last month... at 80 ish KG that felt like a push bike!
What a cracking sight that is 8) 8)
And you're thinking about your next build already, I like the bit where you said "single cylinder, and as powerful as I can find..." :thumbup: :thumbup:
Not the easiest of tasks to come up with something like that to fit the bill :problem:
We'll have to start head scratching :D
Enjoy your summer months Tony, I look forward to what you could be building next come winter :eh:
buzzer wrote:As this build finishes my mind turns to the next project, I have 6 months to think about it as I like to ride over the summer months... Yesterday I moved the cars and bikes out of the garage so I could give it all a good clean. Moving the bikes around made me realize just how heavy the Guzzi feels (200kg) its manageable for me at the moment, but I am sure a time will come when that also becomes too heavy... The Ducati's weigh in at 165- 168 KG and with the high bars, they are easy enough to move around. The Honda feels super light in comparison! Incidentally I rode a Honda Montesa last month... at 80 ish KG that felt like a push bike!
What a superb collection Image
Single cylinder you say.... Any Moto3 bike should do it all pushing around 50 bhp. 250 cc
KTM RC250GP, Honda NSF250R
That is some serious line up :clap: :clap: :clap:
a big single with power? gotta be a husky701 or the ktm version, 70 plus bhp standard :eek2
Honda XBR 500 perhaps
buzzer
Post by buzzer »
been a while since I updated....
I am on the lookout for a KTM 690 as the next build... I love the Honda! its so light and agile :D
I have been using the bikes quite a lot, despite the cold and wet spells of weather! One thing that’s always bugged me on the last Ducati build was the side mounted number plate… so when i was checking the bike over and noticed a crack in the plate, (poor design and manufacture on my part, I am ashamed!) I decided to fit a rear mounted one the same as a lot of bikes use these days, and also the same as I did on the honda build...
I made the bracket out of 12 and 16mm ERW steel tube which I cold bent around a former. it the walls on the former are nice and thick, you can do quite tight bends without kinking. I also made a carbon fiber finisher, using the tyre shape to create a mould. (I covered the tyre with tin foil first!) it came out rather well!
The other thing that bugged me was a slight fluffynes/hesitation on initial acceleration. I backed off the advance just a little and it completely disappeared! Red Vs blue line in the graph. just shows what a small adjustment can make!
Good to hear from you Tony.
Interesting to hear what you have been busy doing bike-wise, and that your next build could be a KTM690.
Glad you have been getting out on the road regardless of the poxy so called summer weather.
I can hardly believe how clean your oven is :lol:
