Re jetting
Re: Re jetting
cybercarl wrote:The top one (power) that's the torque init. :lol: I'm looking forward to your one on Saturday. That will be the first dyno with lager airbox. Should be interesting. :wink:
it will be good to see whats going on with it coz it feel very strong throughout
tank bag packed with tools and jets im not excited much really :lol:
scott02464
Re: Re jetting
Post by scott02464 »
lloydiecbr wrote:
scott02464 wrote:
cybercarl wrote:That looks very good Scott. So is that with just your tinkering or did the dyno guy do make some adjustments. You should be well pleased with mate. Lovely straight torque curve.
Thanks a lot mate it was just with my tinkering, he didn't touch the bike apart from putting it in the machine.
He's made me feel a bit deflated tbh and tried selling me a dynojet kit saying its 'way out' ??
you dont need a jet kit :thumbup:
maybe drop your needles a little
Ok bud, would you suggest having the needles the same height? I'll get a couple of thinner washers, something in between what Iv got on.
What do you think to the air/fuel graph at the bottom, would dropping the needles slightly sort the richness up?
Re: Re jetting
set your needles the same .
dropping the needles will lean it out from 3-7k where your running rich
Re: Re jetting
I would just do the front carb so the rear is slightly richer, or drop them both and use a small shim to richen up the rear a tad. As Hawk has it in his carb set up guide :thumbup:
Re: Re jetting
either way you wont know what works and what dont without putting back on the dyno .
fine adjustment like that you wont feel as in seat of the pants tuning
scott02464
Re: Re jetting
Cheers guys I'll sort the needles out, apart from the mid range does everything else look ok?
My K&N is in need of a good clean...
Re: Re jetting
scott02464 wrote:Cheers guys I'll sort the needles out, apart from the mid range does everything else look ok?
you can get the service kit from oil man cheep .
just dont over oil it like i did the other day coz it runs like crap .
re-cleand it and gave it a very light oiling.
scott02464
Re: Re jetting
Nice1 mate, I ordered a cleaning kit today off the Bay, £9.08 delivered. I'll give it a good clean when it arrives ;-)
Re: Re jetting
I did put mine on the dyno after I'd gutted the airbox internals ages back.
It lost .5bhp over a stock one back-to-back dyno runs with short standard stacks fitted.
But since then I've also modded the snorkel, added a spacer, modified some SP1 intake stacks to fit, etc, etc, and so there will be more to come next time it's measured.
scott02464
Re: Re jetting
Here's a couple of quick vids of me bike being dynoed.
Re: Re jetting
It lost .5bhp
It's strange how something can make it feel like it's an improvement but when dynoed it shows it to be worse. It's like the K&N's, apparently there is more power from an original filter. I wonder if a placebo effect accounts for something. :lol:
How do those modded stacks sound and feel?
Scott those cans are way too quite. :lol: :)
Re: Re jetting
I might see you there, don't know what time I am setting off, but fancy getting a power run and a fuelling check. Will be borrowing your tools if it's a long way out :D
Re: Re jetting
sounds good :thumbup:
the only tool i aint got is a mixture tool but the dyno man will have one :thumbup:
Re: Re jetting
i have the fully modded air box fitted
spacer/gutted/snokel\stacks
only time will tell roll on saturday :thumbup:
just hope i havent lost to much compression since the last run
scott02464
Re: Re jetting
They are straight through blue flames them mate. :lol:
