Well you asked for another Ducati build
Re: Well you asked for another Ducati build
buzzer wrote: Wed Oct 16, 2024 12:36 pm well the tease is over... :biggrin here it is. It’s a 2001 Buell Cyclone. Its a 1200cc Harley engine, tuned by Buell to 95 BHP... Its one owner from 8) new, with 8000 miles on it and its had an absolute fortune already spent on custom parts. Its lived all its life in a dehumidified cocoon!
Not sure what I am going to do with it yet...
A very underrated bike IMHO.
The one you have looks great already :thumbup: :thumbup: :thumbup:
Never thought id say it, but thats bloody nice :thumbup: :thumbup:
Ill get my coffee now go get started :clap: :clap:
haynesjones66
Post by haynesjones66 »
i like the fixed headlight idea, might do something similar myself
buzzer
Post by buzzer »
haynesjones66 wrote: Fri Oct 18, 2024 8:24 pm i like the fixed headlight idea, might do something similar myself
that's the first thing I am changing!
First job has been to address the plastic tank… While it’s not too bad, its already showing signs of bubbling due to the ethanol in the fuel… I hate plastic tanks, so it has to go. Plan was to make an alloy under tank and then make a fiberglass seat and tank cover. However, I had an old Ducati Monster tank that was rotted out on the bottom so I got Arnie the angle grinder out and cut it up… just to see! I was really pleased with the shape and how it fitted! It did of course mean that I would lose that nice Buell filler cap, so instead of using the Ducati one, I made a conversion ring to take the Buell one, it worked a treat.
I made a new bottom for the tank out of some 1.2mm mild steel, and TIG brazed some mounting lugs on, and also a plinth for the fuel tap. This didn’t go well and I got some leaks (good job I pressure tested before putting the bottom in!) The reason was due to my TIG settings… you need both pre AND post gas with braze and you need to flood the weld area with gas before you arc up. The tap plinth brazed on much better. I did mill some shoulders to make it easier as its 10mm thick.
Rather than leave a hard welded edge I planished a 90 degree curve on the edges and then recessed the bottom in.
Next the seat… I quite like the back shape, but not the triangle that hangs down… I decided to use the existing seat as a pattern and make a new one out of fiberglass. The original seat is actually quite valuable so I was keen to keep it nice. I covered it in cling film before covering that with 3″ wide sticky foil tape. It's very thin and moulds to shape, and does a good job of following the contours, its actually fantastic stuff and very sticky! To make the things line up to the new tank I used builders foam, which once dry, I cut to shape with a bread knife. Be a few days before the resin and mat arrives!
No chance of allowing the grass to start growing under your feet Tony :D :D
I like the idea of replacing the plastic fuel tank with a metal one, also a nice move of making a conversion ring so you can use the Buell filler cap :clap: :clap:
haynesjones66
good grief man! slow down and give us mere mortals a chance!! i'm at the stage of making a buck out of ply/plastic/kingspan and eventually fibreglass etc. keep posting progress though. i enjoy watching your work
I watch the work you do and realise i have the hands of a idiot :lol: :lol:
buzzer
Post by buzzer »
haynesjones66 wrote: Sun Oct 27, 2024 8:06 pm good grief man! slow down and give us mere mortals a chance!! i'm at the stage of making a buck out of ply/plastic/kingspan and eventually fibreglass etc. keep posting progress though. i enjoy watching your work
its her fault... she likes to keep me in the garage :lol:
The seat unit is now in shape, next job is to make the actual seat… Not cut it to the end shape yet, still pondering! I must work on my photoshop skills!
Out of the four options, I like option “B” the most,
I think A has the best balanced look 👍
I can’t decide on any of them
They all look great
buzzer
Post by buzzer »
Still undecided on the seat shape but that can wait… for now I have also made the seat base. I bonded in some alloy plates for the rivinuts to secure into. It fits rather well!
That fits like it grew there, good job :thumbup: :thumbup:
buzzer
Post by buzzer »
One thing I have often regretted is not fitting a steering damper… they are difficult to retro fit so I decided to fit one to this bike… This entailed making a lug which I wanted to be a tight fit on the frame…I didn’t have a 30mm cutter, So I used a fly cutter adjusted to size!
A good idea doing that now at this stage :thumbup: :thumbup:
