Hoses have been done with Vinyl and rubber care, engine cleaned all over with a toothbrush and cotton buds, all the corrosion on the rads is polished away, inside and outside of the fairings are spotless too
Oil and Filter just changed too
It's got to get worse before it gets better ! It's worth it in the end :-)Watty wrote:Not the bike, started mucking out the man cave so I can get on winter modding, think a bomb had gone off in there! Will post before and after pics WHEN
I'm done
Make it sound like I didn't do anything thenlloydie wrote:Today I got it started and then swapped virts discs and lines then bleed his breaks
are they "baffles" in those exhausts??? what a waste!!! bike looks good though.
<3 good boylloydie wrote:Sorry youth .
Virt had another lesion on how to undo a bolt and used his hand mussels to pump the break lever while I operated the bleed nipple ! . I also had Virt apply lube to some bolts and find tools oh oh and he topped up the break res with the finest dot 4 I had as his had been shaken up and could be used (full of air bubbles ) .
Tho I must say only a few more lesions and he might be able to get dressed without supervision :-@
