alternative way to get fuel into engine
Re: alternative way to get fuel into engine
What's supposed to be connected on there Tony. I have just looked at my bike and strangely enough I don't have anything connected to that either. :confused
You must have been editing your post as I was writing cause you've changed it. I was going to have a crack at the pies. :lol: So that top outlet on the therm housing, what is it?
It's a blanked-off nothing, goes nowhere, no hose connected to it, just put there as a Japanese April Fool joke.
scottyhatchi
Post by scottyhatchi »
on the choke cable i have come to realise the plastic bit that screw into the carbs that snapped can actually be removed which ive done surely u must be able to buy just that little plastic screw bit on its own rather than buying a whole new cable ?
Snow mobile solution and amongst others >>
>> http://www.vtr1000.org/phpBB3/viewtopic ... 48#p219541
scottyhatchi wrote:on the choke cable i have come to realise the plastic bit that screw into the carbs that snapped can actually be removed which ive done surely u must be able to buy just that little plastic screw bit on its own rather than buying a whole new cable ?
scottyhatchi
wat was that u sent wicky ?? it just comes up wid a post about carbs .
That superhawk link is a good one. Nice solution. :thumbup:
scottyhatchi
oh i see sum1 made 1 so i take it u cant just buy that peice then ?
I don't thinks so, Honda like to make money so sell a complete choke cable. Your best bet is either a bodge or eBay http://www.ebay.co.uk/sch/i.html?_sop=1 ... ble&_rdc=1 Make sure they have the threaded bit on the end.
Or stick a post up in sales and want's. You nether now :wink:
The plastic part comes on the carbs, not with the choke cable. hence why the more durable brass snow mobile part has been employed/slightly modded in the US Superhawk as a replacement. As per the link you can get another set of carbs (ouch) to get the solitary placcy bit you need, or see the David Silvers link for the Honda Starter Valve set kit that might include one - give em a ring to find out but at £35+ *ouch!*.
scottyhatchi wrote:oh i see sum1 made 1 so i take it u cant just buy that peice then ?
scott02464
Post by scott02464 »
That's weird how the coolant pipes bypass your carbs! No bloody wonder we had crossed wires finding them lol!
Spose if your not using it in cold winter then what's it matter.... :lol:
Wonder why they've been bypassed tho... :-(
scottyhatchi
probs the person before me did it as he only used it in the nice weather ... i use it all year rnd tho .. i do know in winter i have some trouble sumtimes getting it started in the mornings like
scott02464
scottyhatchi wrote:probs the person before me did it as he only used it in the nice weather ... i use it all year rnd tho .. i do know in winter i have some trouble sumtimes getting it started in the mornings like
Yeah me too, last year when it was really cold mine wouldn't start!
Ran battery flat trying to crank it over...
Had to jump start it a couple of times off a car battery out the shed, weirdly it fired straight up!?
I don't think the missing coolant hoses will have caused your bad starts as the coolant wouldn't have warmed up before its started running
Cause when your playing with carbs, re-jetting and you have to whip them out 20 or so times.... :lol: :lol:
I would connect it all up properly personally. They are there for a reason. :thumbup:
Probably not but the water warms pretty quick before the thermostat is opened. You think of the temperatures in the cylinders as it's firing. Boom..
edds11
Post by edds11 »
reason for carb warming pipes.........pour a bit of petrol on your hand, its cold, thats because it evaporates very quickly therefore taking heat away from what it touches, add into the equation fast flowing air and petrol and you have the effect of freezing wind. Your carbs would literally freeze up, your jets would block the bore would reduce with frozen air/petrol mixture. this is in extreme cases, our carbs are sat between 2 hot cylinders, above a hot bottom end and out of direct wind contact, therefore not such an extreme condition. Just a thought
edds11
Post by edds11 »
Scotty, when you say you've tried it and it still won't start, did you blank of the vacuum pipe coming from the rear carb inlet (the one that goes to the carb' 4mm)
