just bought 2001 model, first bike for 25 years!
has an occasional clunk at low revs from what appears to be under the tank; front cylinder? under load no problems. checked both CCT,s both appear ok. Bike covered ~21K miles
grateful for any suggestions[/img]
it might not be a clunk,, it could be the reputable pop they do when ticking over at low revs ... the one that also leads to it cutting out some times..
obviously it could be a totally different sound to the one im thinking. but i had the same worries when i first got my storm...
Tank rubber fixings worn/missing?
Seized rear suspension area leading to notchy movement that can be felt via the tank?
Does it do it with a full tank of fuel or a low tank or any amount in the tank (thinking low fuel warning light sender float here you see knocking side)
We need more to go on I feel.
+ 4 on the theory of the bike just spitting back through the carbs occasionally, they all do it now and again. What makes it sound worse is because the air box under the petrol tank is so big, it amplifies the sound
Although it does sound hellish. Sounds like the piston slapping off the top of the cylider head. Worried me for a while till mines were balanced. Usually more noticable when cold.
