VTR Firestorm (Superhawk) Fiche (Exploded Diagram) Images
RedStormV
Post by RedStormV »
Hi,
Got fed up of posting the odd or two one here and there, so thought it was about time the whole lot got posted.
At least now if anyone has any queries they can refer to this or be referred to it or a part / section there of, from a posted reply.
I've included the direct URL link to the image below each one (Right click then chose open in new window or tab etc)
Decals
http://img9.imageshack.us/img9/1175/f3500.tif
Warning Decals & VIN plate
http://img187.imageshack.us/img187/5236/f3400.tif
Fairing Plastics & Mirrors
http://img148.imageshack.us/img148/7029/f3300.tif
Cooling System
http://img25.imageshack.us/img25/5083/f3200.tif
OEM Tool Kit
http://img9.imageshack.us/img9/2605/f3100.tif
Oil Cooler
http://img5.imageshack.us/img5/4435/f3000.tif
Frame & Sub-Frame
http://img509.imageshack.us/img509/8445/f2900.tif
Wiring Harness & Coils
http://img256.imageshack.us/img256/8393/f2800.tif
Battery & Fuses
http://img254.imageshack.us/img254/4643/f2700.tif
Tail Light
http://img410.imageshack.us/img410/9362/f2600.tif
Indicators
http://img187.imageshack.us/img187/1359/f2500.tif
Undertray Assembly
http://img148.imageshack.us/img148/2121/f2400.tif
Rear Suspension
http://img25.imageshack.us/img25/9945/f2300.tif
Swinging Arm & Final Drive Chain
http://img9.imageshack.us/img9/5284/f2200.tif
Side Stand
http://img254.imageshack.us/img254/8450/f2100.tif
Foot Pegs
http://img410.imageshack.us/img410/4751/f2000.tif
Rear Brake Lever & Rear Brake Switch
http://img187.imageshack.us/img187/9499/f1900.tif
Exhaust System
http://img148.imageshack.us/img148/1919/f1800.tif
Air Box & Air Filter
http://img25.imageshack.us/img25/7821/f1700.tif
Seat, Seat Lock & Seat Plastics
http://img9.imageshack.us/img9/3894/f1600.tif
Fuel Tank
http://img5.imageshack.us/img5/2622/f1500.tif
Rear Wheel Assembly
http://img509.imageshack.us/img509/459/f1400.tif
Rear Brake Caliper Assembly
http://img256.imageshack.us/img256/4094/f1300.tif
Rear Brake Master & Slave Cylinders
http://img254.imageshack.us/img254/6640/f1200.tif
Front Wheel Assembly
http://img410.imageshack.us/img410/6582/f1100.tif
Front Brake Caliper Assembly
http://img187.imageshack.us/img187/3314/f1000.tif
Front Suspension / Front Shock Absorbers
http://img148.imageshack.us/img148/7748/f0900.tif
Front Mudguard
http://img25.imageshack.us/img25/7213/f0800.tif
Bottom Yoke (Triple Clamp) & Horn
http://img9.imageshack.us/img9/2407/f0700.tif
Top Yoke (Triple Clamp), Horn & Ignition
http://img254.imageshack.us/img254/4977/f0600.tif
Clutch Hydraulic System
http://img410.imageshack.us/img410/9899/f0500.tif
Front Brake System
http://img187.imageshack.us/img187/3561/f0400.tif
Throttle Cables & Switchgear
http://img148.imageshack.us/img148/2084/f0300.tif
Clocks & Guages
http://img25.imageshack.us/img25/2991/f0200.tif
Head Light & Running Light
http://img9.imageshack.us/img9/3883/f0100.tif
Cooling System Gaskets
http://img5.imageshack.us/img5/1692/eop0200.tif
Head Gaskets
http://img509.imageshack.us/img509/2738/eop0100.tif
Air Suction Valve (Vacuum System)
http://img256.imageshack.us/img256/2774/e1900.tif
Carburetor Component Parts
http://img254.imageshack.us/img254/9028/e1801.tif
Carburetor Assembly
http://img410.imageshack.us/img410/9994/e1800.tif
Water Pipes
http://img187.imageshack.us/img187/263/e1700.tif
Gear Selector Drum
http://img148.imageshack.us/img148/8660/e1600.tif
Gearbox (Transmission)
http://img25.imageshack.us/img25/8452/e1500.tif
Crankshaft & Piston
http://img9.imageshack.us/img9/6700/e1400.tif
Crankcases
http://img254.imageshack.us/img254/1596/e1300.tif
Oil Pump, Oil Filter & Sump
http://img410.imageshack.us/img410/7481/e1200.tif
Starter Motor
http://img187.imageshack.us/img187/6228/e1100.tif
Final Drive Cover & Clutch Slave Cylinder
http://img148.imageshack.us/img148/7207/e1000.tif
Alternator
http://img25.imageshack.us/img25/4486/e0900.tif
Pulse Generator & Starter Clutch
http://img9.imageshack.us/img9/7180/e0800.tif
Clutch Assembly
http://img5.imageshack.us/img5/9821/e0700.tif
Water Pump
http://img509.imageshack.us/img509/7881/e0600.tif
Right Crankcase Cover
http://img256.imageshack.us/img256/74/e0500.tif
Cam Chain & Tensioner
http://img254.imageshack.us/img254/1418/e0400.tif
Camshaft & Valve
http://img410.imageshack.us/img410/5230/e0300.tif
Cylinder Head Rear
http://img187.imageshack.us/img187/3168/e0201.tif
Cylinder Head Front
http://img148.imageshack.us/img148/4690/e0200.tif
Cylinder Head Cover Front & Rear
http://img25.imageshack.us/img25/8075/e0100.tif
If the Mods (have we got any?) or Admins think I'm infringing anything I'm sure this post will self destruct!
RedStormV
Re: VTR Firestorm (Superhawk) Fiche (Exploded Diagram) Image
Post by RedStormV »
Timbo wrote:There's a screw missing on Fairing Plastics & Mirrors (3rd slide) :biggrin :biggrin
Think we all know where there's a screw loose matey - somewhere Upholland way perhaps? :biggrin
V useful, well found.
It's the US one, so shows one or two bits that aren't on the UK one, can't tell if anything's missing, though.
Still doesn't list the terminal bolt in the starter motor as a separate bit :mad2
And what the hell does part 4 in the toolkit do when it's at home?
(Hope it's nothing useful, as I've used mine as a bit of packing ages ago).
RedStormV
Post by RedStormV »
Isn't it a 0.7mm 'feeler' guage type thing for checking gap on brakes?
Certainly something like that iirc
kevg
Post by kevg »
RedStormV wrote:Isn't it a 0.7mm 'feeler' guage type thing for checking gap on brakes?
i don't think i've seen that bit in my kit, maybe its for the spark plug gap if it's 0.7mm
cheerz
kev
rumpleforeskin
Post by rumpleforeskin »
Is there not a part number page to go along with the parts illustration?
Search for link to Ron Ayers in the US - Admittedly Superhawk part no's but 99% the same as Firestorm. Copy'n'paste them into Dave Silvers part no. finder viola!
mark r
Post by mark r »
very useful .
