Goodys
goody
Goodys
Post by goody »
As I got it!
So many things I'd like to do to it so little time (and money!) Image
Still not sure on high levels, don't like the need for pillion footrest extenders.
Beamish
Re: Goodys
Post by Beamish »
Do you need to keep the pillion seat? If not get a cowel then remove the rear pegs. Must admit to liking the high levels personally.
Re: Goodys
You'll find plenty of takers for a swap for low levels on here.
Jbrebel
Re: Goodys
Post by Jbrebel »
I like the high levels 8)
Looks nice in black 8)
SP1's rock!
Re: Goodys
I like hi-level can's too :D It does look nice in black :D
goody
Re: Goodys
Post by goody »
Cleaned it up a bit, all in its had new rear disc and pads, new rear tyre, chain and sprockets, oil, filters, plugs, carbs balanced, shims checked, forks flushed fresh oil, head bearings suspension bearings regreased, stripped and cleaned the calipers, painted the wheels, fork lowers, bottom yoke, calipers. Manual CCTs and VFR clip ons. Removed the little guard from the link pipes ground off the mounting points and give them a brushed finish with wet and dry. Not in the pic new grips and I've put the original screen back on (the black one is cracked).
Re: Goodys
I like the black fork legs and calipers.........nice touch on a good looking bike
