flush front indicators?
mwross1964
Post by mwross1964 »
Anyone know where to get front flush indicators that fit straight on without any additional messing about.
:confused
Cheers.
Mark.
anything with wheels or tits is gonna cost ya money.
but who needs money
Re: flush front indicators?
Far as I know, there's only two choices:
Big oval cat's eyes, which needs a plate behind to hold the nut in, or
http://s616.photobucket.com/albums/tt25 ... side-1.jpg
These, which need two small holes drilling either side of the aperture (good word, aperture).
Sorry about link, I still can't remember how to do this piccy lark.
mwross1964
Cheers Tony.
:biggrin
but who needs money
Jbrebel
Post by Jbrebel »
I got my flush fit oval indicators from here-
http://www.vehicle-wiring-products.eu/V ... cators.php
SP1's rock!
LutonStorm
Post by LutonStorm »
Hey JB,
was there much farting around to fit them? They look good!
Jbrebel
Post by Jbrebel »
Not at all really. They just have a large diameter shaft/plastic nut on the back-like TM says-you might need to fabricate a backing plate of some sort, more so for the fronts.
Saying that the fronts were easy to replace. I had high level cans on mine so I fitted the backs in the tail pod by drilling it. The only issue with that is a) you've got a tail pod with holes in it should you ever want to change back :( b) you need to make sure the rear of the indicators don't foul on the subframe when fitted. The indicator housings are quite long and the wires need room to exit without catching. The other option for the back is integrated indicators in the brake light housing should you not want the mahoosive fecking things Honda fit 8O
Mine worked fine. Had no trouble at MOT time either...However, mini LED/micro LED's are much brighter and more visible to other drivers :think:
The choice is yours :thumbup:
SP1's rock!
