![Problem :problem:](./images/smilies/icon_problem.gif)
indicator spacer
- whitedoggy
indicator spacer
Hi Guys. I'm trying to find spacers so I can fit mini indicators, motrax ones. Any pointers as to which ones will fit. The ones I've got are too small. It's for the front of my 2000 vtr ![Problem :problem:](./images/smilies/icon_problem.gif)
- benny hedges
Re: indicator spacer
use the stem off the oem indicators.
unscrew the little self tapper inside & pop the new ones inside the hole in the stem.
mine are just superglued in and they look ok![Thumbup :thumbup:](./images/smilies/icon_thumbup.gif)
- whitedoggy
THANKS FOR THE INFO. Unfortunatly I haven't got the originals, ![Sad :(](./images/smilies/icon_sad.gif)
Personally i want some yamaha indicators, they're quite genious, (hope i spelt that right), they are rubber stemmed and have a plastic clip that holds them in place! Try sourcing them but if you want mini stuff which IMO ruins the look of a bike then i guess they wont be to your liking.
Red one? Could you confirm my suspicions? Did you use long stalk ones or short ones like on the R1 R6 cos i was looking at fitting YBR125 ones off the rear?
Also did you just cut the inner panel so the rubber would just slot through then clip it?
