This will be a big project and will take too long.
Whatever i will do,i will post here,be sure about it.
Yesterday i bought the front rim (ebay uk)from VTR and rear rim will be the next step.
After that,i will order the front suspension springs and when finish with measurments,i will also order the rear shock.All of them from the german factory Wilbers.
Rear shock will be about 4-5cm shorter than original,cause the new rim in front will make the bike 5cm shorter.
As it has to do about the engine,i will need your help.VTR engine has CCT failure and already need new piston and front head,including the cams.
What is your suggestion about the pistons?JE,or something else?
Are there any improved cams available for the engine?I sent mail to Kent cams but more than one week now,they did not answer.
