Rear Shock
Jester666
Rear Shock
Post by Jester666 »
Daft question but is the rear shock spring removable?
ie Can I change it for another one Hyperpro/Hagon etc? Just trying to improve the back end without the £400 cost of a new shock.
Tight? Me? :lol:
Jester666
Re: Rear Shock
Post by Jester666 »
:thumbup: :thumbup: :thumbup: :thumbup:
Re: Rear Shock
Jester666 wrote:Daft question but is the rear shock spring removable?
Tight? Me? :lol:
here's a very nice yacugar progressive rear spring for firestorm.
£80 from ftr suspension 01284 752 102
if you take your shock to them they will fit the spring for free.
Re: Rear Shock
FirestormMike wrote:Yes you can, a few people have swapped springs. Ask Chris (Sirch354) :thumbup:
Jester, Mike is right, I fitted a Maxton spring to my standard Firestorm shock to suit my body weight. It's definitely better than the standard spring and a cheaper alternative to a more expensive shock. I would still like a more expensive shock sometime, but for now for the money I'm happy with it.
Tim (Timbo) also had a Maxton shock spring fitted to one of his Firestorm's a while back, Although he's not running a Firestorm now I think he was happy with it.
Mine looked like this with the Maxton spring fitted:-
Steve6088
Re: Rear Shock
Post by Steve6088 »
Sorry if this is a stupid question.
Can the shock spring be removed and replaced without any special tools? or would I have to take the shock somewhere?
Re: Rear Shock
Steve6088 wrote:Sorry if this is a stupid question.
You will need a spring compressor for a start, so for the cost of that for one spring change, is it worth it?
Much easier to take it to someone who knows what they are doing!
Griff1977
Re: Rear Shock
Post by Griff1977 »
I've just bought a hyperpro front progressive springs kit inc fitting bits and oil, plus rear progressive coil from the bike show- all in £190 delivered. They are in Coventry, I'm near Oxford and they said they'd fit the rear spring to my original showa shock for free (5 min job), though a local mobile mechanic (he does travel-London, north etc) has a spring compressor and so he is doing it for me. Ive heard it should make a big difference. Planning to clean up swing arm hinging pivot when rear all loose as well- make a proper job of it. I'll let you know how it goes. Hyperpro corporate colour for the spring is purple but I've opted for black as my VTR is yellow- too many strong colours going on there!! Griff. :D
Immediate plans:Clean it!
thumperslaw
Re: Rear Shock
Post by thumperslaw »
Griff1977 wrote:I've just bought a hyperpro front progressive springs kit inc fitting bits and oil, plus rear progressive coil from the bike show- all in £190 delivered. They are in Coventry, I'm near Oxford and they said they'd fit the rear spring to my original showa shock for free (5 min job), though a local mobile mechanic (he does travel-London, north etc) has a spring compressor and so he is doing it for me. Ive heard it should make a big difference. Planning to clean up swing arm hinging pivot when rear all loose as well- make a proper job of it. I'll let you know how it goes. Hyperpro corporate colour for the spring is purple but I've opted for black as my VTR is yellow- too many strong colours going on there!! Griff. :D
Where abouts in oxfordshire you from?
Am based witney but work in oxford.
98 storm with goodies!
Srad seven fiddy stuntbike
K100 "flying brick"
R.I.P engine number 5
Griff1977
Re: Rear Shock
Post by Griff1977 »
Hi. I'm same distance the other side of Oxford than you are! I'm in a place called Lewknor J6 M40. Could go for a ride in the better (warmer) weather!!
