Page 1 of 2
Hi ladies and gents!
Posted: Thu Apr 07, 2011 6:42 pm
by dimesredbeard
Re: Hi ladies and gents!
Posted: Thu Apr 07, 2011 8:17 pm
by tony.mon
Hi. Check out the Sunday rideouts section in the forum.
Posted: Thu Apr 07, 2011 8:27 pm
by benny hedges
hi m8 yeh im just down the 60 from you in warrington.
theres a few of us up this way
it'll be easter weekend before mines back on the road but im always out on me kwak - apart from this weekend cos i got a double christening & a 90th (not mine btw lol)
if it's regular meets & rides you want come and say hello on
http://www.northwestbikers.net - there's loads round your way & always sumat going on.
see if you can get down to the mega meet in wales... should be a crackin laff and a good ride round them valleys
Posted: Fri Apr 08, 2011 8:52 am
by cheekykev
dimesredbeard wrote:
Anyone from the greater manchester area on here ... im based in Droylsden
Hi dimesredbeard and welcome.
Yeah i'm just down the road in Newton near Hyde, there'll be plenty of rides out in the summer months, usaully all kicks off again about Easter time. One of the meeting points local to us is outside Road & Racing Motocyles in Hyde
Posted: Fri Apr 08, 2011 12:46 pm
by dimesredbeard
Cheers for the heads up on the NW forums
I know Hyde town centre well drive through it all the time
You a frequenter of the Bike and Hound ? Is it still open? Not been in there for a bit
(Thursdays topless night aint it??? Or it used to be
My first question then....... The yammy R1/R6 Regulator is that the one to go for cost and reliability wise....had no problems with it upto now but may change if cheap enough for piece o mind
And rear shock spacers i realise it will shift weight tho the front...are stock front springs and bog standard fork oil ok used with the rear spacer? Obviously a better set of fork springs and oil would nt go a miss but cant afford the bits just yet
Posted: Fri Apr 08, 2011 9:00 pm
by tony.mon
As far as i'm aware no R1 or R6 RR has failed, unlike Honda ones.
And the front forks will bottom out under braking, even without the spacer.
It's not really noticeably worse with a spacer in, though.
Posted: Sun Apr 10, 2011 8:09 pm
by sirch345
Welcome to the forum dimesredbeard
The main thing is the rectifier has cooling fins on it. The earlier 16ltr fuel tank models didn't.
If you've not already seen it (from The Workshop Knowledgebase in the Workshop section) have a read of this:-
viewtopic.php?f=31&t=5308&start=0
Posted: Mon Apr 11, 2011 5:55 pm
by dimesredbeard
Cheers for the warm welcome
Had a read of the regulator posts will be doing that mod soon..... may aswell. I use the thumper for work and although folks have said they are thirsty beasts it costs me a tenner to get their and back all week so no quibbles their its less than a bus pass
Just got myself a rear spacer too so will get it fitted soon and see how she feels
This is the first big twin i ve had and must say find it far better than the four pots! And i ve had a few. What life span on a chain for the vtr driven relatively sensibly i would imagine they chomp chains a bit with the torque?
Posted: Mon Apr 11, 2011 6:23 pm
by lloydie
hello and welcome good people on here with all you will ever need to know regarding the storm
Posted: Mon Apr 11, 2011 6:59 pm
by tony.mon
dimesredbeard wrote:Cheers for the warm welcome
Chain wear is ok, although they have lots of torque it comes in relatively gently.
But a scotoiler makes a huge difference, in excess of 20,000 miles isn't at all unusual.
Obviously replace as a set, and for £6 you can try a smaller front as well.
15tooth = excitement, 14 tooth = hello sky.
Posted: Mon Apr 11, 2011 8:19 pm
by AMCQ46
welcome to the fold mate, have fun.
Yes teh spacer makes a big improvement getting the bike to turn in quicker, but dont add too much rear ride height till you have fixed the forks [stiffer springs and thicker oil], or it can get a bit slappy.
Posted: Mon Apr 11, 2011 10:51 pm
by dimesredbeard
So what are we talking max ride height increase with stock fork setup ? Been thinking bout a different front sprocket to be honest and keep stock rear sprocket.... Not really fussed bout top end as I ll never do it! Ha ha
Posted: Mon Apr 11, 2011 11:29 pm
by benny hedges
progressive springs up front and heavier oil plus a spacer in the back & braided hoses - makes a different bike imo.
stick a 15t on the front - you will like it
Posted: Tue Apr 12, 2011 7:25 am
by Eclectic
Changing springs and oil.. is that a job a join can do?
Sent from my Desire HD using Tapatalk
Posted: Tue Apr 12, 2011 7:40 am
by benny hedges
absolute doddle..... you will have to take the forks off though to do it properly.
if you're a lazy batserd you could just undo the fork tops one at a time, pull out the old spring & drop in the new.
even that would be a big improvement over standard.
to do the oil change ideally you need to get the fork upside down to drain it off properly.
then while theyre off have a look at the condition of the chroming & seals.
