help with drain and breather hoses
mark r
Post by mark r »
hello i've gone to put my tank back on today and can't find either of the hoses that fit under the tank and the phone i took the photo's on is no more ,
just wondered if anyone new where they went to , so i could track them back.
Re: help with drain and breather hoses
the hoses have probably dropped down the back, between the rear tank mount and the rear cylinder.
there are a few pics here of where they go.
tbh if they are just the breathers, the bike will run fine without them, assuming you have fitted the vacuum hose to the correct outlet on the (16L) fuel tap?
pics on here somewhere.....
As you're standing looking down above the bike, they're probably hiding in the frame castings on the LH side.
they sort of drop into the rear/inside of the castings.
mark r
Post by mark r »
will take another look but if not , i was looking at replacing them, so just wondered where they go
Down from tank across to LH side frame casting, then follows engine LH side and drop to exit beneath LH rad; they should exit as a clump with a couple of other pipes.
mark r
Post by mark r »
thanks for that , i'll take my fairing back off to see if they are hiding somewhere if not will put new pipe in :D
