Lights modification.
Rad_Draven
Post by Rad_Draven »
Hello guys, I've seen some kind of lights modification long time ago. Im unable to find it again on the forum. It was the front light, and it looked like a cilinder inside the glass. How can I do something like that? And how much it can cost? I need to replace the front light anyway. Thanks a lot.
Re: Lights modification.
Search for HID ;-)
for 3 letter queries use google site search
http://www.google.co.uk/sitesearch/
Might be a problem at MOT time
http://www2.dft.gov.uk/pgr/roadsafety/d ... lamps.html
So you might do better with an Eastern Beaver relay kit with ceramic bulb holder and getting better efficiency from a more conventional bulb set up.
Rad_Draven
The problem that I have is that I'm riding the bike in Spain, and the light slightly spots the wrong side of the road, so I need to do something to fix it for our MOT. So now that I have to change that, I would preffer to put that light. Do you know where could I buy it? Thaks a lot :)
best bet is to use a projector light made for the Spanish market and graft it in how you would do this youtube is your friend
You could as a temporary measure adjust the headlight using the adjuster screw on the bottom right corner of the headlight unit. clockwise to move the beam left - anticlockwise to move it right.
Rad_Draven wrote:The problem that I have is that I'm riding the bike in Spain, and the light slightly spots the wrong side of the road, so I need to do something to fix it for our MOT. So now that I have to change that, I would preffer to put that light. Do you know where could I buy it? Thaks a lot :)
Why?
I've been lighting up the wrong side of the road for years.
Mine is an import, and dips the wrong way.
Every year it gets noticed by the tester, who tells me that it's wrong, and I say:
"Oh, I didn't know that; I'll look out for a RH dip one".
Then he tells me how my exhaust has damaged his hearing, and I go home and change it for a quiet one- just for the afternoon.....
rob's red storm
Post by rob's red storm »
Mine is also an import and dips the wrong way, this year was the first year that it was picked up by the tester. Had a stick on reflector that I chucked on and he was fine with that. Same as tony though, it may have come off soon after...
Sent from my iPhone 4 using Tapatalk
Rad_Draven
Well, the problem in spain is that our MOT is very different to yours. Here they told you: "The light is spotting the wrong side of the road, your'e not allowed to drive it until you replace it" and if the police stops you driving like that, they make you pay a big penalty.
Anyway, I tried to turn the adjuster screw, but im afraid that is not enought here...
If there's not enough adjustment then as an idea you could try shimming the headlight unit where it screws into the front plastic panel, to repoint it further to the right. Otherwise you'll need to get a second-hand headlight for the storm from the Continent / USA.
Stratman
Post by Stratman »
My Storm is a German import. It has a German headlight, but all I do at MOT time is stick some insulating tape on the glass where the deflectors are and it passes every year.
On the way home the tape and the baffles from the exhausts disappear :D
Stratman wrote:My Storm is a German import. It has a German headlight, but all I do at MOT time is stick some insulating tape on the glass where the deflectors are and it passes every year.
you 2 need to meet up and swap headlights, then you are both sorted
Stratman
Post by Stratman »
I thought of that, but it's a long way to go, even to meet half way :D
