anyone know the knack ?
marty b
Post by marty b »
hi all is there a knack to getting the seat off i find it so frustating when i cant get it off that i run out of patience on leave it!!!! help please :(
Re: anyone know the knack ?
put the key in the seat lock and turn it at the same time lift the seat :D
playerone
Post by playerone »
sometimes a good thump is required where the seat rises to pillion, or at least it does on mine.......theres a mod of tapping the rings it hooks onto on the subframe one way or the other to make it a bit easier, cant remember which way tho :oops:
lumpyv
Post by lumpyv »
i have to pull mine up and back . sort of 45 degrees
steeveeo
Post by steeveeo »
Hi
I found mine difficult to get off at first.
TRY THIS
Get hold of the seat next to the tank
pulling the seat from the front ,
towards the rear.
and at the same time lift the rear with ya other hand as the seat moves to the rear ,
it only moves about an inch or less,then it comes of easy.
Seat seems to get a good grip on its fastenings when its in the locked postion.
unlock it first though , :lol:
kind of a slide ,then up past the retaining hooks.
oooh I do like a good tug; :Woohoo1:
steeveeo wrote:Hi
TRY THIS
towards the rear.
Yep that works for me too. Unlock and push back on the seat at the rear of the tank.
Best thing is get it off any way you can & then remove the bloody hooks! End off seat removal problems. :thumbup:
You will lose the seat strap but it's a small price to pay.
Before any one asks I have run mine like this for over four years & have not had any problems, the seat hooks under the tank at the front & is held in by the latch at the back.
Simples.
I pull back on the strap rather than the front of the seat, but I guess it is the same concept.
once you have it off then you can either push the hooks back a bit [with a hammer] or remove them, then it is much easier. I just tapped them back and it works no problem now
marty b
Post by marty b »
cheers people il give them all a try :clap:
Furrybiker
Post by Furrybiker »
I found I had to bash the seat backwards while turning the key, but I found on here the cure. Just bend the loops that the hooks under the seat attach to, forward by about 3mm.
Sorted, well it worked on mine!
Sandyback
Post by Sandyback »
Furrybiker wrote:I found I had to bash the seat backwards while turning the key, but I found on here the cure. Just bend the loops that the hooks under the seat attach to, forward by about 3mm.
by AMCQ46 » Thu Jan 19, 2012 11:27 am
I have the same problem but now confused........do I knock the hooks back (AMCQ46) or forward (Furrybiker) ?
Hooks back or the loops forward, same effect, sorry to confuse :lol:
Sandyback
Post by Sandyback »
AMCQ46 wrote:Hooks back or the loops forward, same effect, sorry to confuse :lol:
Thanks for the clarification. :plainsmile
