and
2. I know the carbs on the 'Storm are a teeny bit on the big size
Yes it will i have one in minetoonarmy wrote:hi tony just ordered some of those t10s led 5 sided will one of those fit my sidelight? ive ordered 4 so that wold work great
carbs are 48mm flat slides diaphraghm operatedlumpyv wrote:i thought i read somewhere they were 52mm. might be wrong though? i also read that they are the largest carbs honda ever used in production. guess that why the old storm likes petrol so much
think you're thinking of the TL1000 there.... 52mm throttle bodies....lumpyv wrote:i thought i read somewhere they were 52mm.
Why not use the SP bodies at 54mm.........benny hedges wrote:lumpyv wrote:......but use the 52mm TL1000 throttle bodies....
what power you think is possible?benny hedges wrote:think you're thinking of the TL1000 there.... 52mm throttle bodies....lumpyv wrote:i thought i read somewhere they were 52mm.
yes, i thought the samewould be nice. unfortunately not that simple.
the early varaderos used a 45mm version of the same carbs, then went to fi.
what would be interesting would be taking a varadero bottom end with all the required senders & sensors, and all the fi gubbins, but use the 52mm TL1000 throttle bodies....
