will this fit a storm
i've tried a cbr954 rear, but that was to wide and to much hassle, i was just wondering if this was lighter than a storms and more importantly will it fit.....
http://www.ebay.co.uk/itm/HONDA-CBR-600 ... 1591179756
Re: will this fit a storm
Dunno.
Probably nothing but spacers needed, but maybe the seller can confirm axle diameter, which will cause a slightly bigger problem if wrong.
Just bearings and a new internal tube, though.
Weight?
Ask him.
mik_str
Post by mik_str »
Based on what I have read elsewhere (Superhawk forum), the 600RR wheel is significantly lighter and uses a larger axle (22mm?). New bearings, possibly spacers and you should be good to go.....
