Chain and sprockets
Hilly
Chain and sprockets
Post by Hilly »
Just bought an 02 firestorm but the chain is at its limit. What do you advise as the best replacement?
bazza696
Re: Chain and sprockets
Post by bazza696 »
I have a gold DID X ring chain, a standard front sprocket and a Renthal rear sprocket(standard number of teeth on both sprockets)
Chain and sprockets
What he said and welcome :)
Hilly
Post by Hilly »
bazza696 wrote:I have a gold DID X ring chain, a standard front sprocket and a Renthal rear sprocket(standard number of teeth on both sprockets)
Thanks. I will get them tomorrow
Supersprox rear is lighter but more expensive.
Looks the biz, though.
Fronts- all seem to be much the same, tbh.
When you fit it, the front one flaps about a bit- that's ok, they all do it.
i got myself a supersprox rear sprocket (£45), its luverly.....mmmmmm
i went +1 on the rear amd -1 talon front sprocket (£20) at least this way i can keep the original chain, i just got to be careful that my speedos slightly out.
Hilly
Post by Hilly »
lloydiecbr wrote:What he said and welcome :)
Thank you for the welcome.
Hilly
Post by Hilly »
tony.mon wrote:Supersprox rear is lighter but more expensive.
Thanks for the info. on the front sprocket. I am waiting for the chain ste to arrive by post. I have gone for the DID gold x ring and standard sprockets. Still waiting for the insurance to come through the post. Got silcolene oil, honda filter and honda spark plugs. I am stripping the bike down and am replacing any worn parts.
vtryorks
Post by vtryorks »
I had a nightmare with this change and I ordered a DID kit.
If you are fitting "DID" sprockets, check the chain tension all the way around when you're done. DID dont make sprockets and the ones which I had were made to a tolerance which I (a newbie) and a race mechanic were shocked at. The result of the first set of sprockets was a chain tension which would potentially have snapped under load even though the slack measured fine at certain points.
In the end I went for Renthal sprockets which are made to a finer tolerance, but never did manage to get it perfect. Even the Renthal are made to a tolerance which surprised the mechanic, who was actually a Renthal dealer. Was quite the experience all around.
If you want more information, I'll happily fill you in on what happened, just PM me as its a long story. I should add, that the DID chain is fine and of good quality.
