hello people ,can i use my carbon can comp cans with high leval link pipes?
also do you have to make your own brackets and lastly will my plate and blinkers still fit with the height?
,I now have trimmed my ,undertray back and fitted a tail tidy with mini blinkys
there should not be a problem with the cans as far as inlet diameter is concerned as long as there the same, without seeing your mini indi's its had to say weither they will get in the way, some high level link pipes aren't as high as you think, for example mig's are some of the highest levels you can get, most aren't that high.
