Speedo Playing up
bazza696
Speedo Playing up
Post by bazza696 »
Just came back from Brands Hatch via Tony's and the speedo started playing up, dropping to zero and the little miles LCD kept going off at the same time.
Half way home the rev counter started to blip as well.
done a search on here and results all lead to a dying R/R.
I confused as I have an new finned RR fitted 3 years ago, but this is the first big run out after fitting one of the yellow upgraded batteries.
I will check the RR tomorrow but could the new battery overloaded the RR causing it to pack up?
Speedo Playing up
I might be wrong but it sounds like a bad earth / loose connector behind the clocks
bazza696
Re: Speedo Playing up
Post by bazza696 »
i will check to battery connectors as well as putting the meter over the battery terminals.
Oh poo! & I was gonna ask to see if you got home ok?
You have PM by the way, or will do in a bit when I send it.
Mac
It'll be a loose connection, if both speedo and rev counter are doing it it's probably an earth rather than live side problem.
Have a look at the green wires going to the back of the clocks. There are several little ring terminals fixed with small screws, they often corrode slightly.
If needed, though, I have a spare set of MPH clocks.
bazza696
Post by bazza696 »
cheers guys, will start fault finding tomorrow when i have clear head
bazza696 wrote:cheers guys, will start fault finding tomorrow when i have clear head
If you catch my man-flu you won't have....
Diabolus
Post by Diabolus »
I had the same issue with a gixer, it was a bad earth :idea:
http://lincsrideouts.co.uk
