What size
chris vtr virgin
What size
Post by chris vtr virgin »
Hi all looking for a quick answer.
Thinking of changing my bars to VFR clip ons to make a bit more upright
Found a set but but the guy reakons they are 37mm.
But i think i need 41mm
Which is correct
Also do you need to trim fairing or anything else.
Chris
Some twins have all the fun !!!!
Re: What size
41mm diameter is the correct size for Firestorm forks. Some say you do need to trim the fairing for VFR bars, while others don't. I think the problem arises when turning the steering on full lock either way. The switch gear touches the fairing.
Re: What size
Yep I have a set on my storm and the pass switch on left hand switch gear touches on full lock, tried to adjust, but just live with it now
chris vtr virgin
Re: What size
Cheers for that guys, :clap: :clap: going to collect a set this afternoon
Will hopefully be fitting on sunday do the cables all fit and also brake and clutch line will they be ok
Cheers again
Chris :D :D
chris vtr virgin
Re: What size
Help got my new clip ons and they are shorter than the storm ones by 20mm
So are these the correct ones i got
There dosent seem to be enough room on them for brake lever then switches and grip
Stratman
Re: What size
Post by Stratman »
