Just in the process of fitting Pro Bolt bits to areas of my Storm. I'm really stuck though on the dial adjusters on the brake/clutch levers. I can't figure how to get the damn things out to put the new ones in.
Can anyone please help me with this one, thanks all.
Dial Adjusters
Dial Adjusters
CBR900rr Fireblade
Dial Adjusters
There is a small alen bolt under the adjuster undo that then pull the two parts apart but be careful as there is a little spring and ball inside that will ping out
Re: Dial Adjusters
Thanks for that fellalloydiecbr wrote:There is a small alen bolt under the adjuster undo that then pull the two parts apart but be careful as there is a little spring and ball inside that will ping out
CBR900rr Fireblade
