190 rear tyre
190 rear tyre
Will a 190 fit on me storm? i have a carbon hugger, aftermarket if that makes any difference?
- agentpineapple
Re: 190 rear tyre
it shouldn't be a problem, although the general thinking is the storm prefers 180's......
Re: 190 rear tyre
well i mite be having the scrubs (hopefully) from Vtrkidda, and they have a 190 in, cant see id lose out much as my storm turns in slightly quicker than id like anyway, we shall see! did you ever use a 190 on yours?
Re: 190 rear tyre
Jus had a look, clearance is very tight with the C/F hugger and im only on a 180 now, any suggestions?
Re: 190 rear tyre
You should be able to space the hugger out a wee bit to give you some clearance.
Re: 190 rear tyre
Hope so otherwise my hugger shall be for sale lol, it will be bloody close
Re: 190 rear tyre
Loydiecbr has a 190 dave he just trimmed a bit of his hugger i think
Loud pipes save lives!
190 rear tyre
You will need to space the hugger up 15-20 mm at the rear mounts both sides for a 190 tyre .
I've just gone back to a 180 and it's much better turns in better and holds a better line in corners . With the 190 I had to fight to hold the line in the bends it just wanted to stand up on me :-( .
