vacuum pipes
edds11
vacuum pipes
Post by edds11 »
Could anyone tell me the size of the nipple needed for the front vacuum pipe( m5 I believe), also how much pipe in length I need to put them both under the seat and what size ( 4mm ? ) it is please :thumbup:
seb421
Re: vacuum pipes
Post by seb421 »
Re: vacuum pipes
http://www.carbtune.com
5mm for the nipple. I bought a packet of 4 brass adapter, used three of them. One for front cylinder and two in the other open end of hoses, superglued in place. I also purchase the end caps to go over them. they are ideal for attaching a carbtune or other brand carbsyncing tool. 4 x 1 metre lengths hose. The left over always comes in handy somewhere else.
http://www.ekmpowershop20.com/ekmps/sho ... ol-9-c.asp
I would highly recommend carbtune.com, very fast efficient service.
Bought a 5mm T-peice from Halfrauds for the take off point on rear carb.
Re: vacuum pipes
If you use an aquarium tee-piece with a valve on it which closed flow in one direction; you can use that output to go to the fuel tap.
Then when you want to balance the carbs, merely close the tap with the engine running, and you can the disconnect the line form the engine to the tee piece and connect it to a balancer.
The vacuum will be maintained from the tee piece to the tap, meaning that fuel will flow and you can take your time balancing and the carbs won't run dry.
It will stay in place if you want to lift off the tank and place it backwards over the seat, and reconnect the fuel lines, but the opposite way round.
